    Module GPS
    UiFlow 2.0
    1.0k
    • Bat21B
      Bat21
      Good morning,
      I'm working with the GPS module and I find that the Get longitude command isn't working correctly.
      The same data is output in both display formats.
      The Get latitude command does work correctly.
      The firmware version is V2.3.3.
      It works correctly in UIFlow 1 FW V1.14.8.
      • kurikoK
        kuriko @Bat21
        @Bat21
        hi, what does you meaned "isn't working correctly"? Can you describe it more specified?
        Bat21B 1 Reply Last reply Reply Quote 0
        • Bat21B
          Bat21 @kuriko
          @kuriko Hello, Longitude decimal "dd.dddd" and longitude "ddmm.mmmmmE/W give the same result.
          • kurikoK
            kuriko @Bat21
            @Bat21
            Can you give us a screenshot for detail?
            • Bat21B
              Bat21 @kuriko
              @kuriko
              • Bat21B
                Bat21 @Bat21
                @Bat21 said in Module GPS:
                @kuriko
                @kuriko
                Any thoughts on this issue?
                I'm at the end of the project, and the readings are displayed in the same format.
                • Bat21B
                  Bat21 @Bat21
