    Tab 5 screen flicker after firmware update
    SOFTWARE
    201
    • JomacJ
      Jomac
      I've only just got my hands on my Tab 5 and after playing with the standard screen I downloaded the official firmware using M5Burner. I erased the memory and then flashed the official firmware. The Tab 5 then boots and when it displays the normal 'Tech' screen, there is a very noticeable flicker at something like 5 or 6Hz and the screen isn't quite as bright as normal. I tried re-flashing a couple of times and its still the same. At this point I downloaded other programs and the flickering is still there.
      Whats happening and where have I gone wrong?
      I started out with absolutely nothing and still have most of it left.
        sapphire
        Do you have the same problem that other people have had?
        https://community.m5stack.com/topic/7737/tab5-display-issue?_=1755381438444
        JomacJ 1 Reply Last reply Reply Quote 0
        • JomacJ
          Jomac @sapphire
          @sapphire said in Tab 5 screen flicker after firmware update:
          No I don't, thats a completely different issue. On my display the picture is perfect other than the backlight flickers at about 5 or 6 Hz. Once I had downloaded and flashed the new firmware, this is when the issue started. Deleting the demo program and installing a couple of other progs makes no difference, the flickering is still there.
            sapphire @Jomac
            @Jomac I also have this problem that happens from time to time I see it on the bottom right side
              sapphire @sapphire
              @sapphire http://192.168.1.61:5244/d/sd_card/mp4/WhatsApp Vidéo 2025-08-17 à 19.35.11_90e31b99.mp4?sign=AF_oijvWOMslZWSURfdyKx0T1D0PJ8FoIx0fS5Uevy0=:0
              JomacJ 1 Reply Last reply Reply Quote 1
              • JomacJ
                Jomac
                I switched the Tab 5 on earlier this evening and this mystery fault seems to have cleared and I'm non the wiser. I must have turned the unit on and off thirty or so times and download several programs before with this fault present each time, so why has it cleared after leaving the Tab 5 alone for 24 hours?
                • JomacJ
                  Jomac @sapphire
                  What is this link for?
                    sapphire @Jomac
                    @Jomac If you watch the video, I have this little defect that doesn't happen often (a flashing).
                    • JomacJ
                      Jomac @sapphire
                      The link doesn't work for me
                      • kurikoK
                        kuriko @Jomac
                        @Jomac Will this situation improve if I re-burn the old version of UiFlow2 firmware?
                        • JomacJ
                          Jomac @Jomac
                          @Jomac said in Tab 5 screen flicker after firmware update:
                          Well I flashed the firmware several times and also flashed a couple of apps on M5Burner and nothing made any difference, everything just flickered so I switched off and left it for the night, next morning I was going to video the issue and when I switched on my Tab 5 again, the fault had cleared.
