    RTC serious bug - easy fix for development team
    7 Posts 3 Posters 3.0k Views
    • G Offline
      gektron
      I've just purchased a Tab5 for our company evaluation for use as a time clock. We want to deploy many of these across multiple sites. So far the development using UIFlow 2.3.3 is working out okay. However I have just come across a serious bug with the hardware RTC in UIFlow as follows:
      When you add a "Set UTC time" block to the program, it generates the following python code:
      rtc.init((year, month, day, 0, hours, minutes, seconds, sub seconds))
      It should be calling rtc.datetime() with these parameters, rtc.init expects slightly different parameters (see https://docs.micropython.org/en/latest/library/machine.RTC.html). Could you fix this bug please and get the block to call the rtc.datetime() function as it is causing me a major road block. As I said seems like a simple fix.
      Additionally do you have the Tab5 camera integration with UIFlow blocks on the roadmap in the near future? Thanks.
      • felmueF Online
        felmue @gektron
        Hello @gektron
        until this gets fixed you could try to use an Execute mpy code block instead with the correct micropython code in it. This block is located under System.
        • G Offline
          gektron @felmue
          @felmue @m5stack thanks for the quick reply Felix. As I understand this feature no longer exists in UIFlow, or at least I can’t find or enable it. Instead you have to define custom block models which seems like a very clunky method with limited scope. Are the execute mpy code blocks still available somehow?
          • kurikoK Offline
            kuriko @gektron
            @gektron
            I have reported this problem to the R&D team!
            The Tab5 camera adaptation is currently pending until Espressif adds MIPI driver support for the ESP32-P4.
            • G Offline
              gektron @kuriko
              @kuriko Thank you for the update. I look forward to the bug fix and the forth coming camera implementation (hopefully Espressif will add MIPI support soon).
              • felmueF Online
                felmue @gektron
                Hello @gektron
                I agree, the Execute mpy code block is a bit hidden in UIFlow2. But as I said before you can find it in System:
                • G Offline
                  gektron @felmue
                  @felmue Doh! I was looking under system at the menu options. I didn't think to click on system for the block menu. Thanks for the guidance.
                  • G gektron referenced this topic on
