    UIFLOW IDE 2.3.0 to Core2 v2.1.7 push don't work
    UiFlow 2.0
      mtc_ndr
      Hello everyone,
      Since upgrading to version 2.3 of the UIFLOW web IDE, when I push the program to the device (core2 v2.1.7), it restarts but there is no effect; it remains on the previous program.
      This can be reproduced on other core2 devices running v2.1.7.
      This fleet is remote, and I am unable to update the firmware remotely.
      The console Core2 :
         _  __ _
      _ ()/ | | _____ __
      | |/ _ \ \ /\ / /
      | || | | | | () \ V V /
      _
      ,||| ||___/ _/_/ V2.1.7
      [INFO] Syncing resources...
      [INFO] WiFi connected!
      [INFO] MD5 mismatch for file: main_ota_temp.py
      [WARN] Failed to download file. code = 403
      [WARN] Retry 1...
      [WARN] Retry 2...
      [WARN] Retry 3...
      File "boot.py", line 45, in <module>
      File "m5sync/sync.py", line 449, in run
      File "m5sync/sync.py", line 329, in run
      File "m5sync/sync.py", line 387, in process_files
      File "m5sync/sync.py", line 52, in calculate_md5
      • kurikoK
        kuriko
        @mtc_ndr
        The file may be deleted on the UiFlow IDE, but the device did not receive the synchronization information or lost the synchronization information, resulting in the device being unable to download the file.
        You can try the following 2 methods:
        1. Reburn the UiFlow2 firmware.
        2. Delete the 2 following files of device:
          mtc_ndr @kuriko
          @kuriko
          Thank you for your response.
          I did this step by step.
          Deleted
          • record.json
          • res.json
          After pushing the code, the problem remains the same., error 403
          So I Reburn the Core2.
          After pushing the code, the problem block on Sync screen, error 403
          I think there is a problem accessing the file bucket on Alibaba.
          Or else the load transmitted by mqtt to the device is not what is expected for res and record json.
          Similar of:
          https://community.m5stack.com/topic/7652/uiflow-2-0-sync-error
