    Error!!!!????
    General
    4.7k
    • N
      Nooblearns
      What's up ya'll!!!
      I'm not sure if I am using this community right, I'm trying to teach myself and I ran into an error trying to download M5 burner.
      Figured I ask here.
      Any information is greatly appreciated.
        ajb2k3 @Nooblearns
        @Nooblearns what error?
        N 2 Replies Last reply Reply Quote 0
        • N
          Nooblearns @ajb2k3
          @ajb2k3 I was trying to burn UI flow to the M5 stick. What I'm reading is I need CH340 or CP210x? My brother a Dev, is gonna stop by tomorrow and try and help.
          I appreciate the reply.
          • N
            Nooblearns @ajb2k3
            @ajb2k3 ERROR: Command not found at ''
              ajb2k3 @Nooblearns
              @Nooblearns have you installed the ESPtools?
              • robskiR
                robski
                so you downloaded M5Burner correct? and it opens ok?
                what exact model of M5Stick you have - you need to choose correct firmware version.
                is your M5Stick com port detected in M5Burner when usb is plugged in to M5Stick?
                • N
                  Nooblearns @robski
                  @robski Yes i downloaded M5 burner and Bruce. I have the M5 stick C plus
                  • N
                    Nooblearns @ajb2k3
                    @ajb2k3 Esp tools I never downloaded.
                    • N
                      Nooblearns @robski
                      @robski I downloaded M5 burner. I have bin, packages, and m5 burner. It's telling me to extract all files, I did that.
                      When I try and follow along with a video on this, my files don't look the same as in the videoIMG_4571 (1).jpg
                      N robskiR 2 Replies Last reply Reply Quote 0
                      • N
                        Nooblearns @Nooblearns
                        @Nooblearns I really appreciate your time and help!!
                        • robskiR
                          robski @Nooblearns
                          @Nooblearns just unzip in to folder before you run M5Burner
                          • N
                            Nooblearns @robski
                            @robski I deleted M5 burner and I am going to start again. Each time i extracted, nothing happened.
                            • N
                              @Nooblearns Let's goo, I think I am getting somewhere, thanks to you peeps!!!
                              • robskiR
                                robski @Nooblearns
                                @Nooblearns not a good start if M5Burner doesnt play game before you even connect your M5Stick
