    UNIT-EARTH with a M5Stack Core - Proper Pin?
    Units
    2.8k
    • W
      wwhite
      Is the the correct code when using a M5Stack core. I don't get any changes when reading the values? Thanks in advance.
      #include <M5Stack.h>
      void setup()
      M5.begin(); // Init M5Stack. 初始化M5Stack
      M5.Power.begin(); // Init power 初始化电源模块
      M5.lcd.setTextSize(2); // Set the text size to 2. 设置文字大小为2
      M5.Lcd.printf("UNIT_EARTH EXAMPLE\n");
      pinMode(26, INPUT); // Set pin 26 to input mode. 将引脚26设置为输入模式
      dacWrite(25, 0); // disable the speak noise. 禁用喇叭
      void loop()
      M5.Lcd.setCursor(0, 80); // Set the cursor at (0,80). 将光标设置在(0,80)
      M5.Lcd.printf("AnalogRead:%d\n", analogRead(36));
      M5.Lcd.printf("DigitalRead:%d\n", digitalRead(26));
      delay(1000);
      • teastainT
        teastain @wwhite
        @wwhite Did you plug the UNIT into the red socket on the left side?
        These inputs are: 21 and 22.
        You could plug it into the discrete I/Os around the base on the right side where you will find 26 and 36.
        • W
          wwhite @teastain
          @teastain Thank you. It's got a grove connector and I didn't want to cut it.
          • W
            wwhite
            I don't recommend this product. This is what it looks like after being in a barely damp plant overnight! No wonder I couldn't get any readings! IMG_9390.jpg
