    File "base/stepmotor.py", line 1, in __init__ ValueError: invalid pin
    Scheduled Pinned Locked Moved Bases
    5 Posts 2 Posters 3.1k Views
      Schnoble
      Hi everyone
      I am trying to use an Atomic stepmotor base (SKU:A132) with an Atom lite (SKU:C008) Uiflow2.0 (v2.2.8) but it does not work.
      I get this error message :
      File "base/stepmotor.py", line 1, in init ValueError: invalid pin
      I think pins are sets correctly :
      base_stepmotor = AtomicStepmotorBase(22, 23, 19, 25, 21)
      I do not understand why it's throwing error and what i am doing wrong ?
      felmueF S 2 Replies Last reply Reply Quote 0
      • felmueF Online
        felmue @Schnoble
        Hello @Schnoble
        you are not doing anything wrong I think. The issue is with UIFlow2 firmware for M5AtomLite. As far as I can tell the default pins are for M5AtomS3 (Lite) and there is one additional pin, which cannot be set from the init block and it is set to a GPIO (8) only available in S3. See here.
        BTW: I've created a PR for the issue. So hopefully it will be fixed in a future firmware version.
          Schnoble @felmue
          Thanks @felmue
          Let's hope
            Schnoble @Schnoble
            For what it worth, I make it work by switching to micropython and replacing
            from base import AtomicStepmotorBase
            by a modified version of stepmotor.py before downloading the code
            If you like using blockly, you need to paste modification each time though...
            • felmueF Online
              felmue @Schnoble
              Hello @Schnoble
              clever! Maybe you could put your modified version into an Execute mpy code (eg. import)? This block can be found under System.
