Using WiFi on Tab5 with the Arduino IDE
I got my Tab5 - cool thing :-) but I I have an issue with WiFi.
Basically the C6 should work as a coprocessor connected with SIDO. This should allow using Wifi as normal with:
#include <WiFi.h> WiFi.begin(ssid, password);
in the Arduino IDE. But instead a runtime error appears, and it restarts amd so on
sdio_mempool_create free:34078468 min-free:34077500 lfb-def:33030132 lfb-8bit:33030132 E (1734) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107 E (1734) sdio_wrapper: sdmmc_card_init failed E (4372) H_SDIO_DRV: sdio card init failed FreeRTOS: FreeRTOS Task "sdio_read" should not return, Aborting now!
Does anyone know how to fix or have just a working example (there isn't any example around and even the P4 example with WiFi in the arduino IDE do not work)
Arduino IDE : 2.3.6; M5Stack Package 3.2.0 (all M5Stack lib on the latest state as well)
@smily77 said in Using WiFi on Tab5 with the Arduino IDE:
This board pkg (3.20) seems to be broken for many of us.
We have had to revert to ver2.14 and I have notified M5Stack support.Try reverting and see.
If still a problem make a simpler de-bug version of your sketch and add complications. -
@teastain thanks but unfortunatly doesn't the Tab5 exist in 2.1.4 an simpler than the below can't the sketch be made:
#include <M5Unified.h>
#include <WiFi.h>
auto cfg = M5.config();
M5.begin(cfg); // ← hier wird intern der C6 hochgefahren
@smily77 a-HA!
Thank you. -
Hi guys
the ESP32C6 is connected via SDIO bus to the ESP32P4 but unfortunately the GPIOs used in Tab5 differ from the GPIOs used by the ESP32P4 eval board.
In other words the pre-compiled Arduino library is setup to use SDIO GPIOs which do not match the Tab5 hardware.
So in order to use Arduino you'll need to pre-compile the Arduino library yourself using the Arduino library builder or setup the build system to use Arduino as ESP-IDF component. Both ways should allow to modify the SDIO GPIOs accordingly.
Note: the SDIO GPIOs used in Tab5 can be found here.
Felix -
This applies as well if you use the M5Stack pkg? - is there a "how to" somewere for this?
Hello @smily77
no, AFAIK there is no specific 'how to' for M5Tab5 - only the generic about how to build your own Arduino library using Arduino library builder or how to use Arduino as ESP-IDF component. See links above.
Felix -
There seams to be an additional Issue the Tab5 uses SDIO2 - The correct GPIO's only don't work
Hello @smily77
I believe SDIO2 is used so the communication between ESP32P4 (master) and ESP32C6 (slave) can be exclusive, e.g. not shared with other slaves.
