    issue with CORE2 library
    SOFTWARE
    6
    7
    5.7k
      matt-praterlabs.com
      Hi All,
      My M5Core2 library fails compiling with
      pngle.c:31:10: fatal error: rom/miniz.h: No such file or directory
      31 | #include <rom/miniz.h>
      compilation terminated.
      Using 2.3.6 arduino ide and latest library (both with M5Stck and ESP Board jsons). I had blank code with just the library and it failed.
      thanks
      • N
        nomuza
        I have the (almost) identical problem:
        pngle.c:34:10: fatal error: rom/miniz.h: No such file or directory
        34 | #include <rom/miniz.h>
        Arduino IDE 2.3.6 + Paper S3
        testing drawImageData.ino example
        https://github.com/m5stack/M5EPD/blob/main/examples/Basics/DISPLAY_URL_JPG/DISPLAY_URL_JPG.ino
        • D
          Dan Perren
          I was experiencing the same issue and through trial and error I resolved it for me by removing the version 3.20 M5Stack board, quitting the Arduino IDE and deleting the username/Library/Arduino15 folder. I then restarted the IDE and installed the version 2.1.4 M5Stack board.
          I then uninstalled the M5Stack library version 0.4.6 and reinstalled it. Has worked successfully on two silicon based Macs. (MacBook Pro M1 and MacStudio)
          • teastainT
            teastain @Dan Perren
            @Dan-Perren Me too!
            After 'letting' Arduino IDE update a bunch of boards and libraries...
            It started to happen.
            Best fix was revert to M5Stack boards to ver 2.14
            (3.20 was the problem.)
            cheers
            • E
              ExpatNoHa
              Reverting to 2.14 worked for me.
              • teastainT
                teastain @ExpatNoHa
                @ExpatNoHa I sent an email to M5Stack Support!
                • teastainT teastain referenced this topic on
                • R
                  raeph
                  The Problem seems to still persist. Had the same issue and solved it this way.
                  Thanks @Dan-Perren and @teastain for the solution!
