    cannot connect M5capsule
    SOFTWARE
    477
    • J
      jgude
      let me start with im a complete software noob.
      I had a m5capsule connecting fine with the UIflow browser earlier and programmed it with a simple led strip. Some how it got reset and i wanted to reload the program on the device. But somehow it doesnt connect to my pc anymore as in no com port shows up etc. what can i do?
      • robskiR
        robski @jgude
        @jgude do you have M5Burner installed? if so does it detect com port there?
        M5StickC, M5StickCPlus, M5StickCplus2,M5GO, M5Core, M5Tough, M5Core2, M5 Demo Board, M5Dial, M5Paper, M5Atom, M5Cardputer, M5StampS3, CoreMP135, StamPLC, AirQ
        • J
          jgude @robski
          @robski burner installed, it is detected (again) on the com port, but when trying to burn it cannot connect
          • robskiR
            robski @jgude
            @jgude with this procedure?
            unit off/ press hold boot/ connect usb/ let boot button off - ?
            • J
              jgude @robski
              @robski yes indeed.. but i get the fatal error it cant connect to espressif device, no serial data received. Do i need to clean it first somehow? Lools like it cannot get mac when i try to use the burn button
              • robskiR
                robski @jgude
                @jgude said in cannot connect M5capsule:
                try erase first before burn
                pressing boot booton on power up is important step on firmware operations
