    [Product] M5StamPLC: ideas for next version
    Scheduled Pinned Locked Moved Features Wish List
    4 Posts 4 Posters 3.7k Views 2 Watching
      Hello guys
      some ideas for the next version of M5StamPLC:
      1. switchable 5 V on Grove ports
      2. switchable 5 V on extension port
      3. LED indicators for the relays
      4. LED indicators for the inputs
      Notes for 1.: the existing ICs can be used by connecting output (P3) of (U5 PI4IOE5V6408) to the enable (EN) of (U4 LPW5209AB5F) instead of having EN tied to SYS_5V.
      Notes for 2.: the existing ICs can be used by connecting output (P1_0) of (U4 AW9523B) to the enable (EN) of (U8 LPW5209AB5F) instead of having EN tied to PMU_5V.
        randybb @felmue
        LEDs for IOs are standard on any PLC device. Display is good, but a simple led is better as it always works regardless of a software.
        • O Offline
          Otis68
          Good afternoon.In such a large case and dimensions, make an expansion module with 16 inputs and 16 outputs. Of the 16 inputs, select and make 2, and if possible, then 3 high-speed encoder inputs. LEDs on the inputs and outputs of the display.
          • chirpychipsC Offline
            chirpychips
            I'd like the RGB LED to be a bit brighter and also to be a full colour addressable pixel LED (WS2811). Currently it's only 3-bit colour and takes up 3 GPIO.
            Would be great to see some expansion modules with the same form factor as the M5StamPLC. I believe a 240V power supply is coming. It would be great to have some mains 210V/220V sensor inputs to handle higher voltage sensing.
