    Tailbat problem: black connector ph2.0-4p
    Modules
    1.2k
    • L
      LeBagh
      I have a tailbat and the black connector fell apart.I cannot refix it on the contacts of the pcb; was it glued? Soldered? What can I do?
        ajb2k3 @LeBagh
        @LeBagh No, the housing clips over the contacts and is held to the PCB only by the contact pins.
        It is not a normal header but it is a 2.0mm header not a 2.96mm header
