    M5 Stamp C3 -> Which Flash Mode to choose in Arduino IDE
    Modules
    3.1k
    • K
      Knobsi
      Hey mates,
      can someone point me out which Flash Mode i should use for the M5 Stamp C3 in Arduino IDE?
      QIO, DIO, QOUT or DOUT
      any help would be great !!
      Thx & cheers.....
      PaulskptP 1 Reply Last reply Reply Quote 0
      • PaulskptP
        Paulskpt @Knobsi
        @Knobsi Hi, your question is already two years old. I guess you'll have found the answer, however I just came across it today. I want to share with you an experience I had yesterday:
        Suddenly I encountered a problem after upgrading the Arduino IDE from v2.3.4 to v2.3.5.
        The board that I use is an M5 Atom Echo which has an ESP32-PICO processor.
        After compiling and building a sketch, that compiled, built, and ran OK with v2.3.4,
        It crashed after compiling and building and running with v2.3.5.
        In the crash report I saw "DIO".
        In Arduino v2.3.5 I checked the setting: > Tools > Flash Mode.
        I saw that the Flash Mode was set for: "QIO".
        After I changed the setting Flash Mode it to DIO, re-compiling and building, the sketch ran OK.
        Regards,
        @Paulskpt
        Coding keeps your mind going
