    M5 Stack StickC Plus2 "Disconnected Server Re-link" in UIFlow2
    M5 Stick/StickC
    556
    • B
      bongraker
      I'm just trying to set up my m5stack stickc plus2 and connect via cloud but I'm getting the red error showing "Disconnected Server Re-link"
      It does occasionally show up green saying "ready" but that's only for maybe a second second then goes back to disconnected. I've checked everything including making sure I'm signed in with the correct account, allowing the device in my firewall settings and it does show as a device in the UIFlow IDE but shows as a red question mark and says "Device type unknown" when I clicked it.
      I'm using the latest 2.2.4 UIFlow2 firmware. Any ideas?
      Thanks!
      • B
        bongraker
        Also worth mentioning that I have no issues connecting using UIFlow v1 firmware and IDE
          m5hehehe
          Have you figured out what is the problem? I'm seeing the same issue
            m5hehehe
            In my case I was able to overcome the issue by configuring a DNS resolver and uploading the code via USB
            import network
            # set CloudFlare DNS resolver
            network.ipconfig(dns="1.1.1.1")
