    Time Problem UTC/localtime
    UiFlow 2.0
    6
    2.1k
    • T
      taunushexe
      Using Time Module
      Localtime: (2025, 3, 24, 6, 0, 56, 1, 82)
      Zone: GMT+1
      UTC: (2025, 3, 24, 7, 0, 56, 0, 83)
      Why is GMT+1 not UTC+1h - instead is UTC-1h
      I expect 2025,3,24,8,0,56,83
      RTC ist total out of sync.
      Have we a NTP get Time Process during TCP connect or not ?
      • T
        taunushexe @taunushexe
        @taunushexe ist a BUG !
        Set to GMT-1 = and localdate is OK
        So GMT+1 is GMT-1
        Houston we have a Sign Problem :-)
        Setup with Webburner ; M5 Dial.
        Issue online.
        • kurikoK
          kuriko @taunushexe
          @taunushexe
          this is a java problem... for example Etc/GMT+8 means GMT-8 actually
          will fix it by using UTC
          • T
            taunushexe @kuriko
            @kuriko UIFLOW is Micropython Software
            maybe i must check if Micropyton Orignal has the same Problem.
            But nice to know :-)
            Anyway Clock is now working :-)
            • P
              PaulSchulz
              Greetings, Does UIFlow 2.0 support half-hour time zones?
              I live in Adelaide/Australia with is currently UTC+1030 (ACDT), but will change back from Summer time shortly to UTC+0930 (ACST)
                smeurai @PaulSchulz
                @PaulSchulz Same here, maybe they forgot or a workaround can be to get rtc time and add 30 min to display correct time, hope its updated soon
