    How to disable M5stack fire power saving
    4 Posts 4 Posters 3.3k Views
    • G Offline
      gbastos
      Hello guys, how can I disable the power saving on M5Stack Fire, so even if the battery is below 25% the M5Stack stills running?
      I tried this
      M5.Power.setPowerBoostKeepOn(true);
      But didn't work, as expected.
      Any solutions?
      • kurikoK Offline
        kuriko
        @gbastos
        Fire does not have power saving function
          peolsolutions
          To disable power saving on the M5Stack Fire, modify the AXP192 PMU settings using the M5Stack library in Arduino. UseM5.Power.setPowerBoostKeepOn(true); to keep power on and prevent sleep mode. Additionally, disable deep sleep with esp_sleep_disable_wakeup_source to ensure continuous operation without unexpected shutdowns.
            felmue @peolsolutions
            Hello @peolsolutions
            just an FYI: M5Stack Fire doesn't have an AXP192 PMU.
            I get the feeling some of your posts are AI generated, no? If I am correct I'd appreciate if you could first verify the technical facts before posting.
            Thank you very much for your understanding.
