๐Ÿค–Have you ever tried Chat.M5Stack.com before asking??๐Ÿ˜Ž
    "Disconnected from Serial Port" while running Hello World on M5Stack (UIFlow2, Ubuntu)
    6 Posts 4 Posters 4.0k Views
      AlphaBrabo
      Issue Summary
      I'm trying to run a simple "Hello World" program on my M5Stack Core using UIFlow2 on Ubuntu 22.04, but I keep experiencing an issue where the serial connection drops unexpectedly. Hereโ€™s what happens when clicking Run or Download the program to the device: a pop up appears, the device connects successfully and logs RAM information:
      heap RAM free: 55760
      heap RAM alloc: 45296
      After a few seconds, I get "Disconnected from Serial Port", and the device is no longer accessible.
      My device shows Public, the device mac, the associated user account, a QR Code ...
      What I've Tried So Far
      1. Checked USB connection
      • Used a high-quality data USB cable.
      • Switched between USB 2.0 and USB 3.0 ports.
      • Tried a different cable and another PC.
      1. Verified Serial Port availability
      After disconnection, I ran ls /dev/ttyACM*
      Before and After disconnection: /dev/ttyACM0 is listed. I can't see if it disconnects when I upload the code
      1. Disabled ModemManager (Ubuntu)
      sudo systemctl stop ModemManager
      1. Flashed the latest UIFlow2 firmware using M5Burner
      • Used M5Burner to install the latest version of UIFlow2.
      • Issue persists even after flashing and rebooting.
      1. Tried a minimal script in UIFlow2
      from m5stack import *
      from m5ui import *
      from uiflow import *
      lcd.clear()
      lcd.print("Hello World", 10, 10)
      The screen does not display "Hello World" before disconnection occurs.
      Questions
      • Why does my M5Stack disconnect from the serial port after a few seconds?
      • Is this a firmware issue or a hardware problem?
      • Could this be related to power management settings or a driver issue on Linux?
      Any help would be greatly appreciated! Thanks in advance. ๐Ÿ˜Š
        schnauzer
        Hi.
        I have the same problem. My Mint Linux pops up the terminal; says it connected; says it disconnected.
        Have you made any progress solving this problem?
        • Z Offline
          Zverik
          Yup, same. Got my M5Stack Basic 2.7 today, burned UIFlow2, but when I try to open a console, or run a program, it shows some log about connecting and disconnecting, and does nothing:
          Connected to Serial Port!
          4592
          heap RAM free: 86704
          heap RAM alloc: 2heap RAM free: 86704
          heap RAM alloc: 24592
          heap RAM 4592
          • kurikoK Offline
            kuriko @Zverik
            @Zverik
            have you flashed the correct firmware?
            Z 1 Reply Last reply Reply Quote 0
            • Z Offline
              Zverik @kuriko
              @kuriko Of course, I've used M5Burner with the latest UIFlow2, as per the documentation. Just tried with the updated 2.2.7 version, still nothing.
              • kurikoK Offline
                kuriko @Zverik
                @Zverik
                that's a bit of weird, i think you should try flash the factory firmware to test out if that was a hardware failure
                With your input, this post could be even better ๐Ÿ’—
