    Is the IO extended unit (U011-B) also compatible with the M5StickC Plus?
    M5 Stick/StickC
    1.3k
      mutsuyuki_
      I am using the M5StickC Plus and want to use the following functionalities simultaneously:
      • list itemWiFi connection
      • Four analog inputs
      • IMU data retrieval
      However, I realized that when WiFi is in use, only up to three analog inputs can be used.
      Question 1:
      Is there a way to use four analog inputs while using WiFi?
      Question 2:
      As a solution for not being able to use four analog inputs, I found an I/O expansion unit called U011-B.
      https://www.electromaker.io/shop/product/extend-io-2-unitstm32f0
      This is designed for M5Stack, but is it also compatible with M5StickC Plus?
        mutsuyuki_ @mutsuyuki_
        I bought and tested an I/O expansion unit called U011-B.
        As a result, I was able to successfully read four I/O signals from the M5StickC Plus from U011-B during using WiFi.
