    AtomS3R bmm150 magnetometer readings
    Atom
    2.0k
      mgrouch
      I'm getting really bad magnetometer readings from AtomS3R bmm150
      using m5stack libraries.
      atan2(mag.x, mag.y) should give some reasonable result in radians.
      However I do not see it being even close.
      My code:
      https://github.com/bareboat-necessities/bbn-atomS3R/blob/07bdf3e322c907e398563786f0af95e70cd635ac/bbn_atomS3R_mahony/bbn_atomS3R_mahony.ino
      I think there is a bug in m5stack unified library which reads that sensor.
      Thanks,
      • P
        proTartareSauce
        Hi there, I'm using an M5core2 with the GNSS module and getting really strange readings form the bmm150 as well. Did you find a fix ?
        Best,
          mgrouch @proTartareSauce
          @proTartareSauce
          m5stack code for calibration is very primitive. It doesn’t do sphere fit. That’s the issue I had
            sywong2000 @mgrouch
            @mgrouch I can use the M5Unified library to read a reasonable readings from the BMM150. Yet have to work on the orientation. In my case I have to invert the X-axis value and Z-axis value and able to calculate into a tilt-compensated headings
