    M5 GNSS module magnetometer false reading
    Modules
    • P
      proTartareSauce
      Hi all,
      I'm using the M5core2 combined with a M5 GNSS module for a position-attitude tracking project.
      I have issues with the values read by the bmm150 (magnetometer).
      Here is the typical values I get when running the getSensorData exemple :
      mag: -991 -32768 -431
      First, these values should be micro Tesla and this is just way too high.
      Second, the Y-value is -32768 which is the lowest possible value for int16_t, the data type returned by bmi270.readMagneticField(mx, my, mz); I guess this indicates a kind of unwanted behavior.
      If anyone has a lead on this problem let me know !
      Thanks,
      PS: other sensors seem to work fine
      Here is the code from the exemple:
       * @file getSensorData.ino
       * @author SeanKwok (shaoxiang@m5stack.com)
       * @brief M5Module GNSS Get Sensor Data Demo.
       * @version 0.2
       * @date 2023-09-15
       * @Hardwares:M5Module GNSS
       * @Platform Version: Arduino M5Stack Board Manager v2.0.7
       * @Dependent Library:
       * M5Module_GNSS: https://github.com/m5stack/M5Module-GNSS
       * Adafruit BMP280 Library: https://github.com/adafruit/Adafruit_BMP280_Library
      #include "M5Module_GNSS.h"
      #include <Adafruit_BMP280.h>
      #define BIM270_SENSOR_ADDR 0x69
      #define BMP280_SENSOR_ADDR 0x76
      BMI270::BMI270 bmi270;
      Adafruit_BMP280 bmp(&Wire);
          // put your setup code here, to run once:
          Serial.begin(115200);
          Wire.begin(21, 22, 100000);
          while (!Serial)
          unsigned status = bmp.begin(BMP280_SENSOR_ADDR);
          if (!status) {
              Serial.println(
                  F("Could not find a valid BMP280 sensor, check wiring or "
                    "try a different address!"));
              Serial.print("SensorID was: 0x");
              Serial.println(bmp.sensorID(), 16);
              while (1) delay(10);
          bmi270.init(I2C_NUM_0, BIM270_SENSOR_ADDR);
          // put your main code here, to run repeatedly:
          float x, y, z;
          if (bmi270.accelerationAvailable()) {
              bmi270.readAcceleration(x, y, z);
              Serial.print("accel: \t");
              Serial.print(x);
              Serial.print('\t');
              Serial.print(y);
              Serial.print('\t');
              Serial.print(z);
              Serial.println();
          if (bmi270.gyroscopeAvailable()) {
              bmi270.readGyroscope(x, y, z);
              Serial.print("gyro: \t");
              Serial.print(x);
              Serial.print('\t');
              Serial.print(y);
              Serial.print('\t');
              Serial.print(z);
              Serial.println();
          if (bmi270.magneticFieldAvailable()) {
              int16_t mx, my, mz = 0;
              Serial.print("mag: \t");
              Serial.print(mx);
              Serial.print('\t');
              Serial.print(my);
              Serial.print('\t');
              Serial.print(mz);
              Serial.println();
          Serial.print(F("Temperature = "));
          Serial.print(bmp.readTemperature());
          Serial.println(" *C");
          Serial.print(F("Pressure = "));
          Serial.print(bmp.readPressure());
          Serial.println(" Pa");
          Serial.print(F("Approx altitude = "));
          Serial.print(bmp.readAltitude(1013.25)); /* Adjusted to local forecast! */
          Serial.println(" m");
          Serial.println();
          delay(500);
