    how to readblock from rfid
    UiFlow 2.0
    5
    2.3k
    • T
      taunushexe
      I have an m5dial - build in RFID reader
      i have 2 midfare Tags -
      RFIDUnit.is_new_card_present
      and read_card_uid works. (2 Tags from 10)
      But how can i read a block in a bytearray ?
      i need a working example
      and only Midfare TAgs working ? or also NTAG Tag (has no uid)
      any max Tagsize (Mifare Classic 1K)?
      my goal ist reading NDEF text Record.
      • robskiR
        robski
        have you checked m5Dial Project Zone examples for rfid part?
        • T
          taunushexe @robski
          @robski said in how to readblock from rfid:
          Sure - only versions found with uid
          old Issue
          https://community.m5stack.com/topic/2535/rfid-unit-reading-and-writing-do-not-work-in-uiflow
          but readBlockStr whith key option not exist
            felmue @taunushexe
            Hello @taunushexe
            please find an M5Dial RFID example reading UID and data in the UIFlow2 Project Zone: M5Dial_RFID_ReadUID_ReadData_UIFlow2.2.2
            • P
              peolsolutions Banned
              Use a compatible RFID reader, authenticate if necessary, and send read commands via software or microcontroller in order to read a block from an RFID tag. Make sure that proper protocols are followed (LF, HF, UHF) and that data is retrieved securely. Integration of identification and access control systems enhances their efficiency.
