    Cardputer keeps restarting.
    9 Posts 3 Posters 4.6k Views
      anubisdarkwatch
      I bought the cardputer exactly a month ago (got it two weeks ago) and have barely used it once or twice, but now when I flash any firmware on it, it stays for about 10 seconds, then restarts, in a loop, nonstop. I've flashed with multiple firmwares and they all have the same outcome. Any fix for this?
      • robskiR Offline
        robski
        have you tried easyloader from M5Stack device documents web?
        A 2 Replies Last reply Reply Quote 0
          ajb2k3 @anubisdarkwatch
          @anubisdarkwatch have you fully charged the battery?
            anubisdarkwatch @ajb2k3
            @ajb2k3 Yes, it is fully charged
              anubisdarkwatch @robski
              @robski I haven't yet, but I will try it.
                @anubisdarkwatch did you erase the cardputer first?
                You always have to erase or you corrupt the firmware
                  @ajb2k3 Going to keep it on a charge, then I will erase. Thanks for all the input.
                    @robski So with another firmware it was showing as having 98% charge, I just loaded UIFlow2 and it showed as 22%. Weird. So I have it charging now, hopefully that is the issue.
                    • robskiR Offline
                      robski @anubisdarkwatch
                      @anubisdarkwatch said in Cardputer keeps restarting.:
                      think it charges battery when connected and ON/OFF switch in ON position
