    Enabling IRda on Serial 2
    infrared irda serial arduino
    13.3k
    • Q
      quangan
      I'm trying to enable IRda TX and RX in the configuration for my M5core in Arduino. I saw in the documentation that this is possible: https://docs.espressif.com/projects/esp-idf/en/latest/api-reference/peripherals/uart.html#api-reference
      However, I don't know what library functions in Arduino I need to call to enable this.
      Here's my code so far:
      #include <M5Stack.h>
      Serial.begin(115200);
      // Serial2.begin(unsigned long baud, uint32_t config, int8_t rxPin, int8_t txPin, bool invert)
      Serial2.begin(115200, SERIAL_8N1, 22, 21,0);
      Any pointers on how to enable IRda tx and rx would be much appreciated! OR please show me where to look for the right configuration keyboard/syntax!
      Thank you!
      • m5-docsM
        m5-docs @quangan
        @quangan
        Hi Maybe you can refer to this article.
        https://www.esp32.com/viewtopic.php?t=276
        /* IRda transmitter */
        //HardwareSerial Serial1(1);
        HardwareSerial Serial2(2); // GPIO 17: TXD U2  +  GPIO 16: RXD U2
            Serial.begin (115200); // (USB + TX/RX) to check
            Serial2.begin(115200); // GPIO 17: TXD U2  +  GPIO 16: RXD U2
            //UART_CONF0_REG  Configuration register 0
            //UART0: 0x3FF40020
            //UART1: 0x3FF50020
            //UART2: 0x3FF6E020
            WRITE_PERI_REG( 0x3FF6E020 , READ_PERI_REG(0x3FF6E020) | (1<<16 ) | (1<<10 ) );  //UART_IRDA_EN + UART_IRDA_TX_EN  "Let there be light"
            //Serial.print("Reg: "); Serial.println(READ_PERI_REG(0x3FF6E020),BIN);  //For Debug only
        }//setup
            Serial.println("Hello");
            Serial2.println("Hello");
            delay(1000);
        } //loop
        M5Stack documentation URL
        https://docs.m5stack.com
        • B
          bigjim991 @m5-docs
          @m5-docs The link should be https://esp32.com/viewtopic.php?t=2766
          (add one 6 to the end)
          • B
            bigjim991
            Does anyone know how to 'redirect' the UART on Pin 17 for sending to Pin 9. This since the IR-Led on the M5StickC and others within the M5-Family is build connected to Pin 9. It would be interesting to have that light use the irDA protocol, since it is already available inside it.
