    Driver Windows for M5 Stickc Plus2
    M5 Stick/StickC
    8
    1.4k
      mrconstantine
      Hello.
      I installed the driver CH9102_VCP_SER_Windows https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/drivers/CH9102_VCP_SER_Windows.exe . But when connected via USB - Type C cable, my device is not displayed in the device manager. There are no COM ports in M5Burner (they are not displayed).
      Please, help me
      OS: Windows 11
      M5Stack Stickc Plus 2
      ajb2k3A R 2 Replies Last reply Reply Quote 0
        ajb2k3 @mrconstantine
        @mrconstantine have you fully shutdown your windows computer and cold booted it from a powered off state?
        Have you tried a different usb cable?
          mrconstantine @ajb2k3
          @ajb2k3 Yes, I rebooted the laptop with the Windows operating system. It did not help. I did not try another USB cable.
          And what are the characteristics of the USB cable? What should the cable be?
            mrconstantine
            Thank you!
            I connected the device with another USB cable. Now the COM port is displayed and the device is visible
              @mrconstantine in most cases it’s bad cables. When buying them make sure to get data cables as power/charge cables don’t have the data wires
              • D
                dmarinho
                I installed this driver on the Mac M1, but I had a connection problem that I didn't have before, I uninstalled it.
                Now I can't connect the m5 to the USB like before, can you help me, because it only opens the console port, bluetouch, and debug!!thanks in advance!
                  ajb2k3 @dmarinho
                  @dmarinho Is it blocked by OSX security system?
                  Have you checked cables?
                  Did you reboot the Mac after installing the driver and before connecting the Stick?
                  Mac have been doing some strange things with security of late.
                  • R
                    RossFall @mrconstantine
                    @mrconstantine
                    You can check the Sorfware antivirus or Microsoft Defender or the app that prevents or blocks the operation. Maybe you have set the system to prevent the operation of the external app. And try to check your cable is a data cable or just charging. If it is charging only, it will not be able to connect. By testing with other devices, observe whether the device being tested has a serial port or not. If the tested device does not have a port, it means that your cable does not support data transfer. You need to find a new cable that supports data transfer.
