    [Product] RS232 in Grove Unit Format
    Scheduled Pinned Locked Moved Features Wish List
    7 Posts 4 Posters 5.6k Views 4 Watching
      Sereneto
      A TTL-RS232 level converter that connects via Grove
      (using a similar design to the Mini CAN Unit: https://shop.m5stack.com/products/mini-can-unit-tja1051t-3)
      1 Reply Last reply Reply Quote 14
        Kinonsc
        https://shop.m5stack.com/products/atomic-rs232-base-w-o-atom-lite
        plus
        https://shop.m5stack.com/products/grove2dupont-conversion-cable-20cm-5pairs
          Sereneto @Kinonsc
          @kinonsc said in [Product] RS232 in Grove Unit Format:
          plus
          I could also just solder a grove connector to some cheap MAX232 boards from Ali and shrink tube them...
          Most of my projects deal with RS232; M5Stack makes RS485 & CAN in Grove format, it would just be nice to have RS232 in that format as well to easily plug-n-play to their MCUs.
          • G Offline
            Glintor
            Did you make this yet?
              Sereneto @Glintor
              @Glintor said in [Product] RS232 in Grove Unit Format:
              Doesn't look like they made it yet.
              • G Offline
                Glintor
                Why design it if you didn't plan to make it?
                  Cairnus
                  M5Stack, any input on this?
                  It's the only communications format not in grove format (as far as I can tell)
