    Grove Male 2 Male adapter?
    General
    • B
      brrainz
      How do I connect the two small M5 modules with a male to male adapter? The grove cable works fine for me but I want a zero length grove male 2 male connection so I can print a 3D case and put both modules into it.
      Thnx
      Andreas
      • E
        erickadengler @brrainz
        @brrainz I think M5Stack are missing a trick, not having a male-male connector. I have a bunch of Neo Hex units I'd like to connect without lots of wires behind them.
          ajb2k3 @erickadengler
          @brrainz @erickadengler you could just try removing the connector and solder wire between each unit or now that you have a prototype made with units, look up the circuit diagrams on the site and build a custom pcb containing the devices.
          Another route is to learn how to make a custom cable/connector.
          BTW the connectors on the devices are male and not female and so adapters must be female not male
