<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Grove Male 2 Male adapter?]]></title><description><![CDATA[<p dir="auto">How do I connect the two small M5 modules with a male to male adapter? The grove cable works fine for me but I want a zero length grove male 2 male connection so I can print a 3D case and put both modules into it.</p>
<p dir="auto">Thnx<br />
Andreas</p>
]]></description><link>https://community.m5stack.com/topic/6888/grove-male-2-male-adapter</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 09:27:34 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6888.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Oct 2024 05:53:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Grove Male 2 Male adapter? on Wed, 15 Jan 2025 16:27:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brrainz" aria-label="Profile: brrainz">@<bdi>brrainz</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/erickadengler" aria-label="Profile: erickadengler">@<bdi>erickadengler</bdi></a> you could just try removing the connector and solder wire between each unit or now that you have a prototype made with units, look up the circuit diagrams on the site and build a custom pcb containing the devices.</p>
<p dir="auto">Another route is to learn how to make a custom cable/connector.<br />
BTW the connectors on the devices are male and not female and so adapters must be female not male</p>
]]></description><link>https://community.m5stack.com/post/27905</link><guid isPermaLink="true">https://community.m5stack.com/post/27905</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 15 Jan 2025 16:27:06 GMT</pubDate></item><item><title><![CDATA[Reply to Grove Male 2 Male adapter? on Wed, 15 Jan 2025 07:21:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brrainz" aria-label="Profile: brrainz">@<bdi>brrainz</bdi></a> I think M5Stack are missing a trick, not having a male-male connector. I have a bunch of Neo Hex units I'd like to connect without lots of wires behind them.</p>
]]></description><link>https://community.m5stack.com/post/27892</link><guid isPermaLink="true">https://community.m5stack.com/post/27892</guid><dc:creator><![CDATA[erickadengler]]></dc:creator><pubDate>Wed, 15 Jan 2025 07:21:22 GMT</pubDate></item></channel></rss>
