    NanoC6 and Zigbee
    General
    1.9k
    • svoopS
      svoop
      I've created a simple "weather station" which uses an ENV IV + NanoC6 to send temp etc to Home Assistant over wifi. Using UFlow 2 to generate the Micropython code and then dive into Micropython from there was a great start.
      However, wifi range is a problem, so I'd like to use Zigbee instead. There's no support for Zigbee in UFlow 2 (for the NanoC6) and apparently it's not in Micropython either. But there are examples for ESP-IDF. I'm no C guy, so this is a bit over my head.
      Are there any plans and chances to see support for Zigbee end device in UFlow 2 (or Micropython for that matter)?
      • kurikoK
        kuriko @svoop
        @svoop
        Will consider add this feature in future
        svoopS 1 Reply Last reply Reply Quote 1
        • svoopS
          svoop @kuriko
          @kuriko Cool, this would be totally awesome!!
          • F
            Felix22
            is there a solution with other units, hardware or Blockly (UIFLow) for using to programming zigbee ?
