    OSError: [Errno 116] ETIMEDOUT
    Modules
    764
    • L
      laursena
      Hey guys,
      I am using a Core2 connected to a M5Stack 4-channel relay. A PAHub is connected to each channel and six I2C Weight Units are connected to each PAHub. So I have a total of 24 I2C Weight Units in use. Unfortunately, I always get an error that I can't solve. This error occurs even when I connect the Core2 directly to a PAHub and six I2C Weight Units. Can someone help me out?
      File "<stdin>", line 166, in <module>
      File "<stdin>", line 126, in setup
      File "unit/weight_i2c.py", line 36, in init
      File "unit/weight_i2c.py", line 40, in _available
      File "unit/pahub.py", line 52, in scan
      File "unit/pahub.py", line 43, in release_channel
        ajb2k3 @laursena
        @laursena You are connecting the hubs to the output of the relays?
        If so it's because the hubs cant communicate. hubs must be connected before the relay
        • L
          laursena @ajb2k3
          @ajb2k3 thank you for your answer. I am connecting the hubs to the output of the relay and I see that the relay doesn't have an I2C output. But I also get the error without using the relay which is odd to me. Do you know why this could be?
            ajb2k3 @laursena
            @laursena if you only have the relay connected but don’t change the code then you will continue to get the error becuase the code is still trying to look for them
            • L
              laursena @ajb2k3
              @ajb2k3 The relay was not connected. I connected the Core2 directly to a Hub and used the following code. Do you see something that could be the reason for the error?
              import os, sys, io
              import M5
              from M5 import *
              from unit import WeightI2CUnit
              from hardware import *
              import time
              from unit import PAHUBUnit
              weight = None
              airScale = None
              notMedical = None
              tareButton = None
              measureButton = None
              kg = None
              i2c0 = None
              pahub_0 = None
              weight_i2c_0 = None
              weight_i2c_1 = None
              weight_i2c_2 = None
              weight_i2c_3 = None
              weight_i2c_4 = None
              weight_i2c_5 = None
              tare_weight = None
              total_weight = None
              adc0 = None
              adc1 = None
              Calibration
              def calibration():
              global tare_weight, total_weight, adc0, adc1, weight, airScale, notMedical, tareButton, measureButton, kg, i2c0, pahub_0, weight_i2c_0, weight_i2c_1, weight_i2c_2, weight_i2c_3, weight_i2c_4, weight_i2c_5
              kg.setVisible(False)
              weight.setText(str('START'))
              time.sleep(5)
              weight_i2c_0.set_reset_offset()
              weight.setText(str('CAL'))
              time.sleep(2)
              adc0 = weight_i2c_0.get_adc_raw
              weight.setText(str('WEIGHT'))
              time.sleep(10)
              adc1 = weight_i2c_0.get_adc_raw
              weight.setText(str('DONE'))
              time.sleep(2)
              weight_i2c_0.set_calibration(0, adc0, 20000, adc1)
              time.sleep(5)
              weight_i2c_1.set_reset_offset()
              time.sleep(2)
              adc0 = weight_i2c_1.get_adc_raw
              time.sleep(10)
              adc1 = weight_i2c_1.get_adc_raw
              time.sleep(2)
              weight_i2c_1.set_calibration(0, adc0, 20000, adc1)
              time.sleep(5)
              weight_i2c_2.set_reset_offset()
              time.sleep(2)
              adc0 = weight_i2c_2.get_adc_raw
              time.sleep(10)
              adc1 = weight_i2c_2.get_adc_raw
              time.sleep(2)
              weight_i2c_2.set_calibration(0, adc0, 20000, adc1)
              time.sleep(5)
              weight_i2c_3.set_reset_offset()
              time.sleep(2)
              adc0 = weight_i2c_3.get_adc_raw
              time.sleep(10)
              adc1 = weight_i2c_3.get_adc_raw
              time.sleep(2)
              weight_i2c_3.set_calibration(0, adc0, 20000, adc1)
              time.sleep(5)
              weight_i2c_4.set_reset_offset()
              time.sleep(2)
              adc0 = weight_i2c_4.get_adc_raw
              time.sleep(10)
              adc1 = weight_i2c_4.get_adc_raw
              time.sleep(2)
              weight_i2c_4.set_calibration(0, adc0, 20000, adc1)
              time.sleep(5)
              weight_i2c_5.set_reset_offset()
              time.sleep(2)
              adc0 = weight_i2c_5.get_adc_raw
              time.sleep(10)
              adc1 = weight_i2c_5.get_adc_raw
              time.sleep(2)
              weight_i2c_5.set_calibration(0, adc0, 20000, adc1)
              weight.setText(str('END'))
              Tare
              def tare():
              tare_weight = sum([weight_i2c_0.get_weight_float, weight_i2c_1.get_weight_float, weight_i2c_2.get_weight_float, weight_i2c_3.get_weight_float, weight_i2c_4.get_weight_float, weight_i2c_5.get_weight_float])
              return tare_weight
              Measure
              def measure():
              total_weight = sum([weight_i2c_0.get_weight_float, weight_i2c_1.get_weight_float, weight_i2c_2.get_weight_float, weight_i2c_3.get_weight_float, weight_i2c_4.get_weight_float, weight_i2c_5.get_weight_float])
              return total_weight
              def setup():
              global weight, airScale, notMedical, tareButton, measureButton, kg, i2c0, pahub_0, weight_i2c_0, weight_i2c_1, weight_i2c_2, weight_i2c_3, weight_i2c_4, weight_i2c_5, tare_weight, total_weight, adc0, adc1
              M5.begin()
              Widgets.fillScreen(0x222222)
              weight = Widgets.Label("250.0", 8, 90, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu72)
              airScale = Widgets.Label("airScale", 5, 7, 1.0, 0x89c6ff, 0x222222, Widgets.FONTS.DejaVu12)
              notMedical = Widgets.Label("Not for Medical Use!", 115, 5, 1.0, 0xff0000, 0x222222, Widgets.FONTS.DejaVu18)
              tareButton = Widgets.Label("Tare", 23, 210, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu24)
              measureButton = Widgets.Label("Measure", 210, 210, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu24)
              kg = Widgets.Label("kg", 230, 90, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu72)
              i2c0 = I2C(0, scl=Pin(33), sda=Pin(32), freq=100000)
              pahub_0 = PAHUBUnit(i2c=i2c0, channel=0)
              weight_i2c_0 = WeightI2CUnit(PAHUBUnit(i2c=i2c0, channel=0), 0x26)
              weight_i2c_1 = WeightI2CUnit(PAHUBUnit(i2c=i2c0, channel=1), 0x26)
              weight_i2c_2 = WeightI2CUnit(PAHUBUnit(i2c=i2c0, channel=2), 0x26)
              weight_i2c_3 = WeightI2CUnit(PAHUBUnit(i2c=i2c0, channel=3), 0x26)
              weight_i2c_4 = WeightI2CUnit(PAHUBUnit(i2c=i2c0, channel=4), 0x26)
              weight_i2c_5 = WeightI2CUnit(PAHUBUnit(i2c=i2c0, channel=5), 0x26)
              weight.setVisible(False)
              weight_i2c_0.set_lowpass_filter(True)
              weight_i2c_1.set_lowpass_filter(True)
              weight_i2c_2.set_lowpass_filter(True)
              weight_i2c_3.set_lowpass_filter(True)
              weight_i2c_4.set_lowpass_filter(True)
              weight_i2c_5.set_lowpass_filter(True)
              weight_i2c_0.set_average_filter_level(50)
              weight_i2c_1.set_average_filter_level(50)
              weight_i2c_2.set_average_filter_level(50)
              weight_i2c_3.set_average_filter_level(50)
              weight_i2c_4.set_average_filter_level(50)
              weight_i2c_5.set_average_filter_level(50)
              weight.setText(str("%.1f"%((tare() / 1000))))
              def loop():
              M5.update()
              if BtnA.wasClicked():
              weight.setText(str('Tare...'))
              time.sleep(3)
              kg.setVisible(True)
              if BtnB.wasHold():
              calibration()
              time.sleep(5)
              kg.setVisible(True)
              if BtnC.wasClicked():
              weight.setText(str('Warten..'))
              time.sleep(10)
              weight.setText(str("%.1f"%((measure() / 1000))))
              kg.setVisible(True)
              if name == 'main':
              try:
              setup()
              while True:
              loop()
              try:
              print_error_msg(e)
              except ImportError:
