    Neopixel connected to EXT.IO2 problem
    Modules
      Marc SKIL
      Hello, my first post here. I am trying to use a Neopixel strand connected to an Ext.I/O2 module (connected to M5StickC2). I can see that I have a Neopixel option for port usage, but no way to write to them. This is a bit of code that let me just light the first pixel:
      import os, sys, io
      import M5
      from M5 import *
      from hardware import *
      from unit import EXTIO2Unit
      i2c0 = None
      extio2_0 = None
      rgb_0 = None
      def setup():
        global i2c0, extio2_0, rgb_0
        M5.begin()
        i2c0 = I2C(0, scl=Pin(33), sda=Pin(32), freq=100000)
        extio2_0 = EXTIO2Unit(i2c0)
        extio2_0.set_config_mode(0, 4)
      def loop():
        M5.update()
        extio2_0.write_rgb_led(0, 0xff0a14)
      Any idea to for further ? Thanks,
        felmue @Marc SKIL
        Hello @Marc-SKIL
        unit EXT.IO2 can only control one (1) RGB LED per output. So what you get is correct. Have a look at the protocol here.
