    GPIO Pins for Ports A, B and C on Core2 AWS
    Core2 for AWS
      SirMichael
      I have an M5Stack Core2 and want to use SoftwareSerial for communications through a couple of the Ports.
      1. Where do I find a document that tells me what GPIO Ports are used for the Ports A, B, and C as well as the pins across the bottom of the M5Stack main?
      2. Where do I find the 4 pin connectors that plug into these ports?
      Sir Michael
        SirMichael @SirMichael
        @SirMichael
        I finally found the pinout document:
        https://docs.m5stack.com/en/core/core2_for_aws
        However, I still need to know where to get the compatible cable connectors.
        Sir Michael
        • teastainT
          teastain @SirMichael
          @SirMichael
          https://shop.m5stack.com/products/4pin-buckled-grove-cable
          all lengths!
          These are actually 'UN-buckled' type but they are an industry standard.
