    ISO RS485 on M5dial
    11 Posts 3 Posters 7.7k Views
    • robskiR Offline
      robski @mukul_100_
      @mukul_100_ what software you planning to use?
      see uiflow2 init example
        mukul_100_ @robski
        i am using platformio right now. thanks
          felmue @mukul_100_
          Hello @mukul_100_
          please find an example here with M5Dial and RS485 unit controlling an ACSSR relay via Modbus protocol.
            mukul_100_ @felmue
            @felmue hi felix sorry for the late reply, finally got a chance to get back to this
            i studied the example but not sure if i understood how to implement the master slave concept through this and also there is a error thrown in
            RS485Class RS485(Serial2, GPIO_NUM_1, GPIO_NUM_2, -1, -1);
            as there are only 4 arguments accepted by the class
            also serial2 needs some tweaking for esp32 right?
            thanks
              felmue @mukul_100_
              Hello @mukul_100_
              I linked the incorrect variants for RS485 and Modbus libraries. Sorry about that. I fixed the example. The libraries I used are the ones from M5Stack.
              https://github.com/m5stack/ArduinoModbus
              https://github.com/m5stack/ArduinoRS485
                mukul_100_ @felmue
                @felmue Hi felix
                the changes you mentioned are in the same example code that is linked above?
                  felmue @mukul_100_
                  Hello @mukul_100_
                  yes.
                    mukul_100_ @felmue
                    @felmue ,did you make any changes in the RS485.h file
                    along these line 46
                    #else
                    #ifndef RS485_DEFAULT_DE_PIN
                    #define RS485_DEFAULT_DE_PIN A6
                    #define RS485_DEFAULT_RE_PIN A5
                    #endif
                    thanks,
                    Mukul
                      felmue @mukul_100_
                      Hello @mukul_100_
                      No.
                      I think you are still on the library I incorrectly linked to in my example before.
                      Incorrect library: https://github.com/**arduino-libraries**/ArduinoRS485
                      Library I used: https://github.com/**m5stack**/ArduinoRS485
                        mukul_100_ @felmue
                        @felmue Hi, felix i got it working finally. The issue is, on platformIO the library Arduinomodbus library and ArduinoRS485 library are the arduino ones and not the m5stack ones which is why i was getting error.
                        A fix to this was to just replace the internal files of library to the m5stack ones from github.
                        Thank you for the help.
