    Issue with default Serial
    Atom
      mrtof
      Has anyone experienced error in Serial data transmission from an Atom Lite BUT ONLY when you simultaneously send Serial data to the Atom?
      I have tested different boards (Teensy, Arduino NG, Arduino Nano), and this is the only one that has this issue.
      I wrote about it here : https://github.com/m5stack/M5Atom/issues/86
      If the computer does not send data to Atom Lite, the Atom send the sequence 0 to 255 without a problem.
      But when I simultaneously send data from the computer to the Atom Lite, there is errors on the sending of the sequence from the Atom Lite.
      What do you think is going on?
      • kurikoK
        kuriko @mrtof
        @mrtof
        Have you tried using other GPIO as serial port? As far as I know, the default serial is internal, and there may be other data interference.
