    m5stack tough programming help
    10 Posts 3 Posters 5.9k Views
      aiconnection
      Hi. I'm looking for some help in programming M5 stack core 2 tough with a RS485 sensor using webui. The sensor is giving out flow rate which needs to be read by m5stack tough device. This data then needs to be propagated to the aws iot core.
      is there any example of the same available that show step by step process.
      is there someone in our community that can show me once
      thanks
      • robskiR Offline
        robski @aiconnection
        @aiconnection so your first task would be to read sensor data using Modbus in to M5Tough controller
        A 2 Replies Last reply Reply Quote 0
          aiconnection @robski
          @robski
          tasks are:
          interface layout on screen with live data values
          establish rs485 sensor connection
          then connectivity to mqtt broker
          could you please help
          thanks
            @robski can you please guide me resources as to how to work with uiflow 2.0 to setup blocks to read modbus data. I know the communication protocols for my sensor. Being newbie I have no concept of uiflow workability with respect to this unit
            Any help or video link would be great
            felmueF robskiR 2 Replies Last reply Reply Quote 0
              felmue @aiconnection
              Hello @aiconnection
              please find an M5Tough Modbus example switching an ACSSR relay on and off in the UIFlow2 Project Zone: M5Tough_Modbus_ACSSR_Test_UIFlow2.1.5
                aiconnection @felmue
                @felmue thanks will check ✅
                  aiconnection
                  Is it possible i could request yourself for configuration for one tough unit with one sensor setup. I can provide you with access to my machine.
                  I can compensate for time if that helps.
                  Sunny
                  Vancouver Canada
                  WhatsApp 6043582900
                  felmueF A 2 Replies Last reply Reply Quote 0
                    Hello @aiconnection
                    thanks for asking, but no, I have no interest in doing that, sorry.
                    That said, have you tried to communicate with the sensor?
                      aiconnection @aiconnection
                      @aiconnection thanks
                      I have not yet tomorrow I will try
                      Regards
                      • robskiR Offline
                        @aiconnection said in m5stack tough programming help:
                        can you read any modbus data from mentioned sensor using any of available modbus test tools? Just to confirm that communication to sensor over modbus is fine.
