    MQTT UIFlow problems
    19 Posts 5 Posters 41.9k Views 2 Watching
      ajb2k3 @dvd78
      @dvd78 said in MQTT UIFlow problems:
      @heybin thank you, this evening i will try...
      also, if i can, i think then the image used to insert text, label etc...in the m5 is too little
      Use the internet browsers zoom function.
      • world101W Offline
        world101 @ajb2k3
        @ajb2k3 said in MQTT UIFlow problems:
        What Operating system do you use?
        What M5 are you using?
        I'm on a Mac with OS 10.13.6 (High Sierra).
        I have the m5stack Fire (red) hardware running v1.1.1.
        Is MQTT working for you?
          ajb2k3 @world101
          @world101
          Yes, but I'm worried about the restarting.
          I only have an M5Core
          • world101W Offline
            world101 @ajb2k3
            I have a m5stack grey as well that I will try tonight.
              dvd78
              i have an M5core too but mqtt is not working yet
                ajb2k3 @dvd78
                @dvd78 Update firmware to 1.1.1 to get MQTT working.
                  dvd78 @ajb2k3
                  i did it yesterday, do i need to download a new version?
                    heybin
                    @dvd78 Sorry, yesterday our engineers forgot to update....
                    now, already fixed, refresh web page it will be ok
                    world101W D 2 Replies Last reply Reply Quote 0
                    • world101W Offline
                      world101 @heybin
                      @heybin
                      MQTT working good for me now with both of my grey and fire m5stack cores. I have tested cloudmqtt and io.adafruit. Thanks for fixing it!
                        dvd78 @heybin
                        @heybin thank you, problem is solved.
                        bye
                          The_Stacker
                          I tried the same blocky today. It uploaded but on the display I only see: error ImportError('mqtt need download...'.)
                          I am using an M5Stack Fire, firmware 1.1.2.
                          I have a local MQTT broker running on an Onio Omega and the upload is done with a Windows 10 computer.
                          Any help would be appreciated.
                          • world101W Offline
                            world101 @The_Stacker
                            @the_stacker
                            Instead of running the program directly from uiFlow (which is the triangle button at the top-right), just click the Download option from the hamburger menu.
                              The_Stacker
                              Thanks! That worked.
                              Just out of curiosity: What's the difference between the two?
                              • world101W Offline
                                @the_stacker said in MQTT UIFlow problems:
                                Run is just for quick testing of your program. It is erased on a reboot. Download will add the program to the flash storage on the device so you can access it from the APP.LIST menu (middle button when the M5stack is booting up - inbeteeen upload and setup).
