    MQTT UIFlow problems
    UIFlow
    5
    19
    40.0k
    • world101W
      world101 @heybin
      @heybin said in MQTT UIFlow problems:
      Very sorry, we will fix it today,
      Has it been fixed yet? I'm trying the example, but after downloading the MQTT example flow to my m5stack Fire, it just freezes. It is not responsive until I reset it.
      https://m5stack.github.io/UIFlow_doc/cn/zh_CN/MQTT/Example.html
      My flow:
      cloudmqtt settings:
      Here are the logs from cloudmqtt.com. Not sure how to resolve the socket error.
      2019-01-22 19:07:18: mosquitto version 1.5.5 starting
      2019-01-22 19:07:18: Config loaded from /var/lib/mosquitto/19639/mosquitto.conf.
      2019-01-22 19:07:18: Opening ipv4 listen socket on port 29639.
      2019-01-22 19:07:18: Opening websockets listen socket on port 39639.
      2019-01-22 19:07:18: Opening ipv4 listen socket on port 19639.
      2019-01-22 19:09:09: New client connected from 64.100.78.39 as cloudmqtt-st-ui-0.9613626986254669 (c1, k60, u'oklhhzzb').
      2019-01-22 19:09:10: Socket error on client cloudmqtt-st-ui-0.9613626986254669, disconnecting.
      2019-01-22 19:09:11: New client connected from 64.100.78.39 as cloudmqtt-ws-ui-0.6445892594600325 (c1, k60, u'oklhhzzb').
      2019-01-22 19:10:05: Client cloudmqtt-ws-ui-0.6445892594600325 disconnected.
        What Operating system do you use?
        What M5 are you using?
          ajb2k3 @dvd78
          @dvd78 said in MQTT UIFlow problems:
          @heybin thank you, this evening i will try...
          also, if i can, i think then the image used to insert text, label etc...in the m5 is too little
          Use the internet browsers zoom function.
          • world101W
            world101 @ajb2k3
            @ajb2k3 said in MQTT UIFlow problems:
            I'm on a Mac with OS 10.13.6 (High Sierra).
            I have the m5stack Fire (red) hardware running v1.1.1.
            Is MQTT working for you?
              ajb2k3 @world101
              @world101
              Yes, but I'm worried about the restarting.
              I only have an M5Core
              • world101W
                world101 @ajb2k3
                I have a m5stack grey as well that I will try tonight.
                • D
                  dvd78
                  i have an M5core too but mqtt is not working yet
                    ajb2k3 @dvd78
                    @dvd78 Update firmware to 1.1.1 to get MQTT working.
                    • D
                      dvd78 @ajb2k3
                      i did it yesterday, do i need to download a new version?
                      • H
                        heybin
                        @dvd78 Sorry, yesterday our engineers forgot to update....
                        now, already fixed, refresh web page it will be ok
                        world101W D 2 Replies Last reply Reply Quote 0
                        • world101W
                          world101 @heybin
                          @heybin
                          MQTT working good for me now with both of my grey and fire m5stack cores. I have tested cloudmqtt and io.adafruit. Thanks for fixing it!
                          • D
                            dvd78 @heybin
                            @heybin thank you, problem is solved.
                            bye
                            • T
                              The_Stacker
                              I tried the same blocky today. It uploaded but on the display I only see: error ImportError('mqtt need download...'.)
                              I am using an M5Stack Fire, firmware 1.1.2.
                              I have a local MQTT broker running on an Onio Omega and the upload is done with a Windows 10 computer.
                              Any help would be appreciated.
                              • world101W
                                world101 @The_Stacker
                                @the_stacker
                                Instead of running the program directly from uiFlow (which is the triangle button at the top-right), just click the Download option from the hamburger menu.
                                • T
                                  The_Stacker
                                  Thanks! That worked.
                                  Just out of curiosity: What's the difference between the two?
                                  • world101W
                                    @the_stacker said in MQTT UIFlow problems:
                                    Run is just for quick testing of your program. It is erased on a reboot. Download will add the program to the flash storage on the device so you can access it from the APP.LIST menu (middle button when the M5stack is booting up - inbeteeen upload and setup).
