    ENV Hat 3 and StickC Plus 2 [Wire.513] requestFrom(): i2cRead returned Error 263
    17 Posts 3 Posters 8.1k Views 1 Watching
      felmue @PascalS
      Hello @PascalS
      hmm, your code works for me.
      Note: I don't have an ENV III hat, but I have the ENV III unit which I used to simulate ENV III hat. So it could be something subtle between the two making it work for me.
      That said, I suggest you first try with the ENV III example alone and if that still doesn't work try to only init and read either qmp or sht3x and see how that goes.
        PascalS @felmue
        @felmue Thanks for your test.
        Unfortunately I cant get either of them to connect.
        Is their a difference between Hat and Unit? Which library versions did you use?
          ajb2k3 @PascalS
          @PascalS HATS use different pins to UNITS
            felmue @ajb2k3
            @PascalS
            the only difference between Hat and Unit (apart from the different GPIOs it uses as @ajb2k3 pointed out) is that the Hat is powered by 3.3 V from M5StickCPlus2 whereas the Unit is powerd by 5 V (with an internal DC/DC converter).
            I used the M5Unit-ENV library, copied the code you posted and manually wired the Unit to the Hat port. In other word I used exactly the code you posted without any modifications.
            Sorry, at this point I have not more ideas as to why it wouldn't work on your side.
              PascalS @felmue
              @felmue From your posts, I get the feeling that you have a lot of knowledge. :)
              As a last ressort, I tried to find a I2C scanner sketch and ended up with the following code.
                Rui Santos
                Complete project details at https://randomnerdtutorials.com
              #include <Wire.h>
                Wire.begin();
                Serial.begin(115200);
                Serial.println("\nI2C Scanner");
                byte error, address;
                int nDevices;
                Serial.println("Scanning...");
                nDevices = 0;
                for(address = 1; address < 127; address++ ) {
                  if (error == 0) {
                    Serial.print("I2C device found at address 0x");
                    if (address<16) {
                      Serial.print("0");
                    Serial.println(address,HEX);
                    nDevices++;
                  else if (error==4) {
                    Serial.print("Unknow error at address 0x");
                    if (address<16) {
                      Serial.print("0");
                if (nDevices == 0) {
                  Serial.println("No I2C devices found\n");
                else {
                  Serial.println("done\n");
                delay(5000);
              I was not sure, but in all the sketches they used sda=0 and scl=26.
              If I scan those, I cant get any devices found. However, if I scan the standard sda/scl = 21/22, then I find two devices (propably build into the Stick itself).
              Is this a sign for an hardware failure?
              Greetings Pascal
                felmue @PascalS
                Hello @PascalS
                from your first log I think the ENV III Hat was recognized properly else the log would have ended with either of the "Couldn't find ...".
                Anyways, please find an I2C scanner for internal, Groove and Hat here.
                P 2 Replies Last reply Reply Quote 0
                  PascalS @felmue
                  @felmue Thanks for the link.
                  Strangely, they are now not showing up (not found is now in the log). That wasnt before.
                    PascalS @felmue
                    The port scan went as expect, only internals are found.
                    I2C Scan - internal
                    ................................................................................0x51 ......................0x68 ......................
                    I2C Scan - Groove Port
                    I2C Scan - Hat Port
                    Does that mean a hardware error?
                    Greetings Pascal
                      felmue @PascalS
                      Hello @PascalS
                      hmm, have you tried to power cycle M5StickCPlus2?
                      1. disconnect USB
                      2. remove HAT
                      3. press and hold power button until green LED lights up
                      4. release power button - green LED goes dark - M5StickCPlus2 is now off
                      5. re-attach HAT
                      6. re-connect USB - M5StickCPlus2 powers on
                      7. re-test
                      P.S. if that doesn't make the HAT show up in the I2C scan or make it work with the original program then I am afraid that yes, there might be a hardware issue.
                        PascalS @felmue
                        @felmue Thanks for your help :)
                        Propably it is a hardware failure, I do not get any i2c signals back.
                        Wil return it and run it with new hardware. I update the thread when I heard back from the seller.
                        Thanks for your help!
                        Greetings Pascal
                          PascalS @felmue
                          @felmue Unfortunately, also a newly bought M5Stick and a newly bought ENV hat didn´t change anything.
                          Could it be that the hat port uses another Wire?
                            felmue @PascalS
                            Hello @PascalS
                            hmm, that is really strange. Do you have any other hat to try if the hat port works for you in general?
                            ENV III hat is supported in UIFlow2. Maybe try with UIFlow2? Just to see if it works that way.
                              PascalS @felmue
                              @felmue You were right, in UIFlow 2 it worked perfectly fine. However, I need them to work in Arduino, so that it fits with our current framework.
                              Do you know were the difference between UIFlow 2 and Arduino is?
                                felmue @PascalS
                                Hello @PascalS
                                at least we know now that the hardware is ok.
                                Apart from that I am stumped. Sorry.
                                  PascalS @felmue
                                  @felmue Finally I got the solution using separate Wires and PlattformIO to manage my libraries :)
                                  With the following ini file (PlattformIO config file)
                                  [env:miniscale]
                                  platform = espressif32@6.1.0
                                  board = m5stick-c
                                  framework = arduino
                                  lib_ldf_mode = deep
                                  monitor_speed = 115200
                                  build_flags =
                                  	-DCORE_DEBUG_LEVEL=0
                                  	-Wl,--allow-multiple-definition
                                  lib_deps =
                                  	https://github.com/m5stack/M5StickCPlus2.git
                                  	m5stack/M5Unit-ENV@^1.0.1
                                  Not knowing why, but I need the "-Wl" to run at all and the "--allow-multiple-definition" flag for the hat to work in conjunction with sensors mounted to the groove port.
                                  It worked, however, I need to change the I2C begin call from "Wire0" (just called Wire) to the secondary I2C channel Wire1
                                  Before:
                                  while (!qmp.begin(&Wire, QMP6988_SLAVE_ADDRESS_L, 0, 26, 400000U)) {
                                       Serial.println("QMP6988 not found");
                                  After:
                                  while (!qmp.begin(&Wire1, QMP6988_SLAVE_ADDRESS_L, 0, 26, 400000U)) {
                                  Maybe this helps someone in the future :)
                                    ajb2k3 @PascalS
                                    @PascalS Now I see the problem.
                                    Wire is hard defined and set to internal.
                                    You need to use Wire1 to access the external devices.
                                    I vaguely remember reading about this issue before but as I don't have arduino I had forgotten about it.
                                    Thanks for the reminder.
