    2RELAY on Core2 v1.13.6
    22 Posts 3 Posters 20.9k Views 1 Watching
      Robertof @cryptospok
      Hello @cryptospok :
      It worked well on my hardware. In the example I will send you, you can alternate the address between 0x25 (default) and 0x30. If the M5 is disconnected while the address is set to 0x30, you will have a problem.
      This can possibly be solved by writing the address to the EEPROM and retrieving it at startup.
      Best regards,
      Roberto.
        Robertof
        cryptospokC 1 Reply Last reply Reply Quote 0
          • cryptospokC Offline
            cryptospok @felmue
            Hi Felix,
            I removed the original battery and the gray part, bought the M5GO2 to replace it, but now I'm not even using it.
            I'm trying with just one module, but when I use the examples (I tried with my code and it didn't work either), I get the message that the module is not attached... I tried with each of them individually.
            Thank you.
              cryptospok @Robertof
              Hi @Robertof,
              Did you use UIFlow1?
              I didn't find the 2RELAY module in UIFlow2.
              I'll try to reproduce your tip and see if it works.
              Thanks!
              R 2 Replies Last reply Reply Quote 0
                Hi @cryptospok .
                In my tests, I received that error when there was a conflict with the I2C address.
                I used Uiflow V1.13.6; it’s a short text for 2Relay, and I also had trouble finding it.
                I’m sending you the modified version that includes storing the I2C address in EEPROM.
                If you need to save the state of the relays, you can also store it in memory.
                Saludos
                Roberto
                  Hi @cryptospok .
                      Hi @Robertof,
                      I reproduced and understood your code, but as you can see in the images, nothing happens.
                      I'm also using UiFlow 1.13.6, it seems that there is some error in the module library...
                      I'm testing with only one 2RELAY module at a time, but both have the same problem.
                      I think the connection is fine... if I put the battery module underneath, the Core2 works without the USC-C connection, that is, with the attached battery (M5GO2 module).
                      Could there be an update in the Core2 firmware?
                      Thank you very much for your help!
                        felmue @cryptospok
                        Hello @cryptospok
                        something is very strange. Try a simple internal I2C scan and see if the 2Relay module shows up.
                        • Without any 2Relay module stacked the result should be: [52, 56, 81].
                        • With one 2Relay module stacked the list should be something like: [37, 52, 56, 81].
                        Note: I don't have an 2Relay module so I cannot test this myself.
                          cryptospok @felmue
                          Hi @felmue,
                          With one 2RELAY module, the result is: [52, 56, 64, 81, 102] and without is [52, 56, 64, 81]...
                          Sorry, I'm just starting with this...
                          Thank you very much...
                            felmue @cryptospok
                            Hello @cryptospok
                            ok, I sorted the list w/o 2Relay out. I was testing with an M5Core2 v1 initially and it looks like you have an M5Core2 v1.1. So I re-run the test with an M5Core2 v1.1 and with that I get the same result [52, 56, 64, 81] as you without 2Relay.
                            So that would mean your 2Relay for some reason is using I2C address 102 (decimal) which is 0x66 (hex).
                            Try to run below code and hopefully that will work.
                              cryptospok @felmue
                              @felmue, the screen shows numer 1, only...
                                Hi @cryptospok
                                “It is correct that it gives you 1, it is the firmware version (I have the same version), now you can breathe easy. In the example I sent you, change all the 37s to 102 and the texts 0x25 to 0x66. It should work.
                                felmueF cryptospokC 3 Replies Last reply Reply Quote 0
                                  felmue @Robertof
                                  Hello @cryptospok
                                  like @Robertof says - 1 is the firmware version. At least now you know your 2Relay is alive, your M5Core2 can finally talk to it, and which I2C address it is using. (And if you are ever in doubt again, you can use the I2C scan method again to find its current I2C address.)
                                      @Robertof ab @felmue, thank you very much!
                                      Now everything works!
                                      I finally understood what was going on... I did some tests and then I managed to put an address in one module, then in the other and then I can access both at the same time. One of them was at 0x32 and the other at 0x33. I need 4 relays for my project... now the conditions acquired by a BME688 will change the states of the relays.
                                      You helped a lot, not only to solve my problem but also to understand the process.
                                      Success and health to you all!
                                      felmueF R 2 Replies Last reply Reply Quote 0
                                        felmue @cryptospok
                                        Hello @cryptospok
                                        you are welcome. I am glad to hear you got it working the way you wanted.
                                        And you!
                                          Hi @cryptospok .
                                          I’m glad you resolved it. I also experienced the frustration of not being able to solve the problems and seeing time pass without finding a way out. Fortunately, Felix was there to advise me and provide an example that I could adapt to my needs. Good luck with that project, and we’ll meet again around here.
                                          Until next time,
                                          Roberto.
                                            Robertof @felmue
                                            Hi @felmue
                                            Friend, thank you very much for your interest in our problems.
                                            Cheers.
