    ATOM_SPK, no sound output
    Atom
    2.8k
    • H
      HappyUser
      Dear all,
      I am trying this device : https://shop.m5stack.com/products/atomic-speaker-base-ns4168 using the software from this link (https://github.com/m5stack/M5Atom/tree/master/examples/ATOM_BASE/ATOM_SPK/PlayRawPCM)
      This is the message i get when resetting the atom lite :
      ets Jun 8 2016 00:22:57
      rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      configsip: 188777542, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff0030,len:1344
      load:0x40078000,len:13964
      load:0x40080400,len:3600
      entry 0x400805f0
      E (303) esp_core_dump_<V͡� Incorrect size of core dump image: 0
      M5Atom initializing...OK
      E (82) I2S: i2s_driver_uninstall(2048): I2S port 0 has not installed
      E (83) I2S: i2s_check_set_mclk(253): ESP32 only support to set GPIO0/GPIO1/GPIO3 as mclk signal, error GPIO number:120
      E (89) I2S: i2s_set_pin(314): mclk config failed
      I2S Write
      I know the software is running through some checks in the software i have build in.
      But i do not here any sound. No beep at startup and no soumd when i press the button.
      This function returns a false : _AtomSPK.begin()
      The weird thing is that the definition is : bool ATOMSPK::begin(int __rate) but it is called without __rate defined.
      Within the begin function the error occurs in : err += i2s_set_pin(SPAKER_I2S_NUMBER, &tx_pin_config);
      Any idea?
      • G
        Genesis17 Banned @HappyUser
        • G
          Genesis17 Banned @Genesis17
          • konacurrentsK
            konacurrents
            I too have the ATOM_SPK and the sample programs run but create no sound, even with the earphone jack.
            https://docs.m5stack.com/en/atom/atom_spk
            The PlayRawPCM program runs but no sound.
            Also the PlayMP3FromSD is missing files, such as AudioFileSourceSD.h.
            Has anyone got these to work?
            I can get the beep program here to work
            https://github.com/PaulskPt/M5Stack_M5Atom_EchoSPKR
            But it seems this program makes a constant hum sounds always, and the beep when button pressed. I assume the battery will die faster too.
            ps. What's up with tagging posts as being "OLD" - when it's a year ago, but the programs being tried are 4 years old. It sure seems to me that the "thread" of any issue, even decades old, should still be used to keep that context intact. Oh well..
