    Cannot upload any images to my M5dial , not through UIflow 2.0 or arduino
    3 Posts 2 Posters 1.8k Views
      mukul_100_
      i tried one example of M5gfx called drawImageData which is giving output image as per the btye array but when i put values i got from converting an image to c i cannot display anything
      Thanks for the help
        ajb2k3 @mukul_100_
        @mukul_100_ I don't work in arduino so I cant help much but.
        Did you completely replace all the byte array data?
        Did you change the arduino code to match the data of the byte array like image size?
          mukul_100_ @ajb2k3
          @ajb2k3 i did, but it just doesn't show the image . I tried inserting the byte array to an other online complier and it gave the output as required
          can you please tell me what you use for images as UIflow 2.0 doesn't work for me as well
          thank you
