    Why is the Serial.print() not working in the M5NanoC6 unit?
    SOFTWARE
    2.4k
    • B
      BoM_M5
      Why is the Serial.print() not working in M5NanoC6 controller?
      • teastainT
        teastain @BoM_M5
        @BoM_M5 Do you have USB CDC On Boot "Enabled"?
        In the 'Tools' drop down.
        • B
          BoM_M5 @teastain
          @teastain Thank you for your tip! After activating USB CDC for Boot to - Enable the Serial.print() worked as it should. /BoM_M5
          PaulskptP 1 Reply Last reply Reply Quote 1
          • PaulskptP
            Paulskpt @BoM_M5
            @BoM_M5 I had the same problem today. In Arduino IDE v.2.3.3, BOARDS MANAGER, searched for esp32. Found "esp32" from Espressif Systems. It appeared that I had version "3.1.0 RC" installed. On Espressif's site on Github I saw that the latest stable version is: "3.0.5", so I downgraded to 3.0.5. Then I saw that the M5NanoC6 was available via: Tools -> Board -> esp32 -> M5NanoC6. After having selected this board, I saw also that: Tools -> CDC on Boot was "Enabled". I saw that there was here no more option "Disabled".
            From this moment all Serial.print and Serial.println command worked as expected.
            Coding keeps your mind going
