    lvgl on m5sack cores3
    Squareline Studio / LVGL
    6.2k
      mnhj
      hi i got a new m5stack core s3 and i want to use squreline studio with lovyan gfx and it does not work . can somone help
        ajb2k3 @mnhj
        @mnhj what do you mean by doesn't work?
          mnhj @ajb2k3
          @ajb2k3 I want to use arduino ide for programing not uiflow and if you know about tft espi user setup then can you please share the configuration for m5core s3 and when I follow the sticker inside the m5core s3 the screen does not work it just stays blank and no backlight so can you share a code that works
          • robskiR
            robski @mnhj
            @mnhj said in lvgl on m5sack cores3:
            show us a sample of your code which isn't working
            "when I follow the sticker inside the m5core s3 the screen does not work" - what is this?
            M 2 Replies Last reply Reply Quote 0
              mnhj @robski
              @robski
              //sample code arduino
              #include <LovyanGFX.hpp>
              // Custom class derived from LGFX_Device for M5Core S3
              class LGFX : public lgfx::LGFX_Device
              // Panel instance for ILI9342
              lgfx::Panel_ILI9342 _panel_instance;
              // SPI bus instance
              lgfx::Bus_SPI _bus_instance;
              // PWM light instance
              lgfx::Light_PWM _light_instance;
              // Touch screen instance for FT5x06
              lgfx::Touch_FT5x06 _touch_instance;
              public:
              LGFX(void)
              { // Bus configuration
              auto cfg = _bus_instance.config();
                // SPI bus settings
                cfg.spi_host = SPI3_HOST;
                cfg.spi_mode = 0;
                cfg.freq_write = 40000000;
                cfg.freq_read  = 16000000;
                cfg.spi_3wire  = false;
                cfg.use_lock   = true;
                cfg.dma_channel = SPI_DMA_CH_AUTO;
                cfg.pin_sclk = 7;
                cfg.pin_mosi = 6;
                cfg.pin_miso = 0;
                cfg.pin_dc   = 4;
                _bus_instance.config(cfg);
                _panel_instance.setBus(&_bus_instance);
              { // Panel configuration
                auto cfg = _panel_instance.config();
                cfg.pin_cs           = 5;
                cfg.pin_rst          = 48;
                cfg.pin_busy         = 6;
                cfg.panel_width      = 320;
                cfg.panel_height     = 240;
                cfg.offset_x         = 0;
                cfg.offset_y         = 0;
                cfg.offset_rotation  = 0;
                cfg.dummy_read_pixel = 8;
                cfg.dummy_read_bits  = 1;
                cfg.readable         = true;
                cfg.invert           = false;
                cfg.rgb_order        = false;
                cfg.dlen_16bit       = false;
                cfg.bus_shared       = true;
                _panel_instance.config(cfg);
              { // Backlight configuration
                auto cfg = _light_instance.config();
                cfg.pin_bl = 45;
                cfg.invert = false;
                cfg.freq   = 44100;
                cfg.pwm_channel = 7;
                _light_instance.config(cfg);
                _panel_instance.setLight(&_light_instance);
              { // Touch screen configuration
                auto cfg = _touch_instance.config();
                cfg.x_min      = 0;
                cfg.x_max      = 319;
                cfg.y_min      = 0;
                cfg.y_max      = 239;
                cfg.pin_int    = 38;
                cfg.freq = 1000000;
                cfg.pin_sclk = 18;
                cfg.pin_mosi = 23;
                cfg.pin_miso = 19;
                cfg.pin_cs   = 5;
                _touch_instance.config(cfg);
                _panel_instance.setTouch(&_touch_instance);
              setPanel(&_panel_instance);
              // Create an instance of the class
              LGFX display;
              void setup(void)
              display.init();
              display.setTextSize((std::max(display.width(), display.height()) + 255) >> 8);
              if (display.touch())
              if (display.width() < display.height()) display.setRotation(display.getRotation() ^ 1);
              display.setTextDatum(textdatum_t::middle_center);
              display.drawString("touch the arrow marker.", display.width() >> 1, display.height() >> 1);
              display.setTextDatum(textdatum_t::top_left);
              std::uint16_t fg = TFT_WHITE;
              std::uint16_t bg = TFT_BLACK;
              if (display.isEPD()) std::swap(fg, bg);
              display.calibrateTouch(nullptr, fg, bg, std::max(display.width(), display.height()) >> 3);
              display.fillScreen(TFT_BLACK);
              uint32_t count = ~0;
              void loop(void)
              display.startWrite();
              display.setRotation(++count & 7);
              display.setColorDepth((count & 8) ? 16 : 24);
              display.setTextColor(TFT_WHITE);
              display.drawNumber(display.getRotation(), 16, 0);
              display.setTextColor(0xFF0000U);
              display.drawString("R", 30, 16);
              display.setTextColor(0x00FF00U);
              display.drawString("G", 40, 16);
              display.setTextColor(0x0000FFU);
              display.drawString("B", 50, 16);
              display.drawRect(30, 30, display.width() - 60, display.height() - 60, count * 7);
              display.drawFastHLine(0, 0, 10);
              display.endWrite();
              int32_t x, y;
              if (display.getTouch(&x, &y)) {
              display.fillRect(x - 2, y - 2, 5, 5, count * 7);
                mnhj @robski
                @robski ```
                this image
                  mnhj @mnhj
                  @robski ```
                  this image
                  the circled area is the sticker ia am talking about
                  • robskiR
                    robski @mnhj
                    @mnhj have you tried something simple first to start with it ?
                    M 1 Reply Last reply Reply Quote 2
                      mnhj @robski
                      @robski yes the simple use example I have used before
