    (ESP32 Ethernet Unit with PoE) Compatibility Sanity Check
    Modules
    • T
      typedepr
      Hello I was hoping if I could get some help with compatibility/feasibility check with my configuration.
      ESP32 Ethernet Unit with PoE + Grove2Grove Expansion Unit connected to
      • Mini CAN Unit
      • I/O Hub 1 to 6 Expansion Unit
      1. Will I/O hub interfere with CAN unit?
      2. Is the Grove2Grove unit necessary or can I just hook the two units up in parallel (if I don't need on/off + current meter)
