f_mount failed: (3) The physical drive cannot work
Hi guys, im having trouble trying to use my SD card in my m5cardputer, i already tried format the sd card to FAT32
error :
[ 1110][W][sd_diskio.cpp:547] ff_sd_initialize(): APP_OP_COND failed: 1
[ 1110][E][sd_diskio.cpp:805] sdcard_mount(): f_mount failed: (3) The physical drive cannot work
Card Mount FailedIm using the SD_Test example and the sd card is a SanDisk 16gb made in Taiwan
After some research i found that sandisk made in Taiwan can happen this problem, i tested with another sd card and its all good.
