    Can't program M5Stack Core2 with USBv1.2 module, wrong boot mode detected 0x17
    Core2 for AWS
    1.3k
      mtrobregado
      Using Arduino IDE I am able to program hello example program with M5Stack Core 2 for AWS and M5GO Bottom2 for AWS connected.
      However, with M5Stack Core 2 for AWS and USB v1.2 module. I get error "Failed to connect to ESP32: Wrong boot mode detected (0x17)! The chip needs to be in download mode".
      How do I solve this problem?
      Regards,
      Markel
        mtrobregado
        The cause of the problem is that I selected GPIO0 as SPI slave select at USBv1.2 module.
        Regards,
        Markel
          mtrobregado
          It still happens. Any permanent solution to the problem>
