    cardputer stuck on develop
    UIFlow
    8
    24
    12.6k
    • T
      ToxicAvenger
      just got my cardputer loaded apps and it bricked in black screen then added UIflow. Now it comes on but stuck on develop app when i open it it says private at top, mac#, email and web id to uflow2.stack.com/ but when i got there its just a older forum.any help on what to do what be appricated i really wanna play with it. oh when i go back and try to add any apps or erase there just errors and it wont let me do anything
        Did you erase before burning UIFlow2?
        Did you agree to bind the cardputer to your account?
        Did you sign into M5burner with you forum details?
        Are you sure you went to the UIFlow2 website?
        Did you sign into UIFlow2 with you forum details?
        • T
          ToxicAvenger
          Total newbie here, I didnt erase before I added UIFLOW2. I do thinking i binded it . Everything I found on UIFLOW2 website looks like it was abandoned 2 years ago. Im signed into there forum. Is there any way i can reset this thing fresh and start over, what should I do?
            ajb2k3 @ToxicAvenger
            @toxicavenger UIflow 2 was updated a few weeks back but the engineers have been on tour
            I am in the process of uploading a series of videos on installing UIFlow2 on YouTube
            • T
              ToxicAvenger @ajb2k3
              @ajb2k3 whats your youtube and are you doing a video on how I can fix this issue, also when will your video be put on?
                https://youtu.be/bnw0tPslV2o?si=jE61HjFvSB90atxy
                • T
                  @ajb2k3 -chip auto --port COM6 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x9000 C:\Users\lemstudent\Desktop\M5Burner-v3-beta-win-x64\packages\tmp\uiflow2-cfg.bin
                  esptool.py v4.6.2
                  Serial port COM6
                  A fatal error occurred: Could not open COM6, the port doesn't exist
                  This is what i get when I try to
                  • T
                    ToxicAvenger
                    When i reset it says com 5 then com 6 then
                    --chip auto --port COM6 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x9000 C:\Users\lemstudent\Desktop\M5Burner-v3-beta-win-x64\packages\tmp\uiflow2-cfg.bin
                    esptool.py v4.6.2
                    Serial port COM6
                    Connecting...
                    A fatal error occurred: Failed to connect to Espressif device: No serial data received.
                    For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
                    • robskiR
                      robski @ToxicAvenger
                      @toxicavenger said in cardputer stuck on develop:
                      esptool.py v4.6.2
                      Serial port COM6
                      Connecting...
                      try to press and hold boot button for few seconds while plugging in usb to it .....and keep on/off in off position so m5stamp is powered up from usb not from battery
                        Try different cables. Not all cables are the same and some USBC cables don’t appear to work.
                        • T
                          ToxicAvenger
                          @ajb2k3 tried 4 different data cables, still same result. Do you think its defective or is it me?
                            Does Windows show any errors with the Com port?
                            • T
                              @ajb2k3 when I do the reset with go and reset button before trying to burn it pops up a window show port5 then another saying port6. When I do anything after that it only gives option for port6 and nothing works on it
                                Does windows hardware manager or what ever its called show an error with the ports?
                                • RuelvilloR
                                  Ruelvillo
                                  When in doubt, G0 and RST it out, hold G0 and tap RST and then let go of G0.
                                  • W
                                    wilsoreal
                                    has anyone found a solution, i am having the same problem
                                      @wilsoreal said in cardputer stuck on develop:
                                      Have you watched the video I linked to above?
                                      • W
                                        wilsoreal @ajb2k3
                                        @ajb2k3 yea but still cant erase my sd and when i try to navigate anything in UI flow 2 it just doesnt work
                                        • R
                                          ROLF_STEINER
                                          hi guys!!! same thing here too....
                                          I used multiple cables (no result)
                                          I updated softwares like a collector in a bunch of them...(same results)...
                                          im absolutely lost....
                                          so if someone see the light please share the trick...0_1715919681849_49fe5e9d-cbe7-4bf7-a20b-41c468144631-Captura de pantalla 2024-05-17 a las 00.16.41.png Captura de pantalla 2024-05-17 a las 00.16.41
                                          Captura de pantalla 2024-05-17 a las 00.16.54
                                          Captura de pantalla 2024-05-17 a las 00.17.05
                                          Captura de pantalla 2024-05-17 a las 00.19.24
                                          • R
                                            ROLF_STEINER @ROLF_STEINER
                                            @rolf_steiner 0_1715919754111_e65ec64d-476a-4348-b3ba-5aa2e8278b4b-Captura de pantalla 2024-05-17 a las 00.16.41.png Captura de pantalla 2024-05-17 a las 00.16.41
                                            0_1715919776087_d7f2a03d-e560-4cd2-8112-b037947185cb-Captura de pantalla 2024-05-17 a las 00.16.54.png Captura de pantalla 2024-05-17 a las 00.16.54
                                            0_1715919798187_0042aa19-4ca4-42d3-9ac9-49e45cb656d8-Captura de pantalla 2024-05-17 a las 00.17.05.png Captura de pantalla 2024-05-17 a las 00.17.05
                                            0_1715919817648_d392fe34-7bc3-41fa-a53c-753f7b2bfd19-Captura de pantalla 2024-05-17 a las 00.19.24.png Captura de pantalla 2024-05-17 a las 00.19.24
