[Product] Simple plastic back for Core Basic / Core2 / CoreS3
It would be nice if you sold a simple plastic back for the Core series, no pins/connectors, no battery, just something to cover the back
maybe with screw mount holes or magnets if you want -
We don't have a 3D printer
sounds like a you problem :P
Plenty here: https://shop.m5stack.com/collections/m5-modules/BASE
All the current offerings have either batteries, add significantly to the thickness, have pins/ports or are of significant cost just to use as a back cover.
We have a bunch of Core Basic deployed and took the guts out of the included Battery Bottoms and put tape on the gaps. Since they're always powered, we had a few batteries start to bloat and also occasionally something would short the pins, so gutting them was the easiest solution.
Not everyone needs batteries or extra expansion, and an extra plastic piece wouldn't cost much. I just though it would be nice to have just a simple piece of plastic cover... potentially with screw slots to aid in mounting
