    M5Burner Error Burn Bin to Cardputer After Burn UIFlow2.0
    General
    18
    8.8k
      ajb2k3 @lamfan
      @lamfan You need to put the cardputer into "Bootloader" mode to burn firmware.
      https://youtu.be/bnw0tPslV2o
      • L
        lamfan
        @ajb2k3 said in M5Burner Error Burn Bin to Cardputer After Burn UIFlow2.0:
        Thanks @ajb2k, I can burn the firmware now. Can you tell me where I can get the shipping firmware?
        I love to use the keyboard and radio app. Thank you!
          ajb2k3 @lamfan
          @lamfan it is there in M5Burner already (or was last time I checked
          • L
            lamfan @ajb2k3
            @ajb2k3 found it, thank you!
            • R
              ROLF_STEINER
              hi guys!! I have worst error for my cardputer , now says:
              Erase Flash
              File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool.py", line 17, in <module>
              import esptool
              File "/Applications/M5Burner.app/Contents/Resources/packages/tool/esptool/init.py", line 816
              raise FatalError(f"Unable to verify flash chip connection ({e}).")
              SyntaxError: invalid syntax
              0_1714969618004_4cfa4ae8-3cae-4b48-a034-a0e434728d9e-Captura de pantalla 2024-05-06 a las 01.24.26.png Captura de pantalla 2024-05-06 a las 01.24.26
              help please
                That means that it didn't detect the controller. are you sure you have the correct USB data cable connecting the controller to the host computer and have installed the drivers along with ESP-IDF?
                • R
                  ROLF_STEINER @ajb2k3
                  @ajb2k3 hi mate, not sure how that can be checked but as soon I plug the cardputer the system do.
                  how can I confirm if my mac have the right drivers needed?
                  thanks in advance....
                  0_1715008188829_57290239-d78d-4c19-80fa-a34a0a2cc92a-Captura de pantalla 2024-05-06 a las 12.07.47.png Captura de pantalla 2024-05-06 a las 12.07.47
                  • R
                    ROLF_STEINER @ROLF_STEINER
                    @rolf_steiner said in M5Burner Error Burn Bin to Cardputer After Burn UIFlow2.0:
                    my last update is this status now.....
                    after all my intents to fix this situation, now trying to "burn" appears this:
                    0_1715014753140_27561bf8-3146-45fd-9229-e1b016d8b072-Captura de pantalla 2024-05-06 a las 13.57.27.png Captura de pantalla 2024-05-06 a las 13.57.27
                    sad thing, this frustrates a lot.
                    in other hand, i can't format any Micro SD if I put one in the cardputer....
                      https://youtu.be/bnw0tPslV2o?si=nnY0J2NaieR57g8u
                      • R
                        good morning mate!
                        thanks for all you support!!
                        If I follows the youtube link, step by step, after the actions required at the second 44, this appears in my screen:
                        0_1715092713857_eca05025-c81a-40df-acfb-8b2084bb10aa-Captura de pantalla 2024-05-07 a las 11.31.05.png Captura de pantalla 2024-05-07 a las 11.31.05
                        I´m lost..... I cant understand why doesnt recognize the cardputer....
                          Try a different USB cable
                          • R
                            Results after changing USB cable:
                            0_1715115244559_60ac29dc-918d-4eb8-b8ea-6a4b5ca5441c-Captura de pantalla 2024-05-07 a las 17.52.46.png Captura de pantalla 2024-05-07 a las 17.52.46
                            looks like the device are connected in a right manner, but half second later appears the "Get mac failed" in red rectangle.
                            Weird thing is the message inside the "Burn UIFIow2" area, in every "cancel, erase, start" button the loading circle keeps moving eternally.....
                            • G
                              gocr8
                              This is happening to me too. Serial monitor seems to show a connection and clicking the reboot button reboots the device but I can't get any other connection. I've tried all the different baud rates.
                              Also on Mac 2017 macbook air with MacOSsierra. but also had same problems on m1 macbook air.
                              0_1715699168474_3e27b9d8-bb1f-4da8-9202-f1ffde571b19-Screen Shot 2024-05-14 at 11.03.42 AM.png Screen Shot 2024-05-14 at 11.03.42 AM
                                Have you installed Xcode and ESP-IDF?
                                • R
                                  Xcode
                                  in my situation, install Xcode is impossible bcz my mac is in OS El Capitan version 10.11.6 early 2015...(too old i think::::) I´m searching a solution... yet
                                    Like my 2012 OSX Laptop, you wont be able to use it for dev with out ESP-IDF and Xcode.
                                    Try manually installing ESP-IDF and VSCode but I doubt you will be able to use it for programming.
                                    This is one of the Major issues with Apple computers.
                                    • G
                                      gocr8
                                      ESP-IDF
                                      Well at least that gives me some sense of avenues forward. Thank you. What are the other options for burning the software? I have some rasberry pi's and picos, and Chrome seems to have some ability to interact with the unit.
                                      Edit: Xcode and possibly another driver CH34x_MAC got it working.
                                      THANK YOU!
