    Unable to read temperature value from SHT30
    General
    11
    4.8k
      Surya
      I'm attempting to read temperature values from the SHT30 (Yanmis SHT30) sensor. However, I'm encountering an error mentioned below.
      Can someone kindly provide me with guidance or solutions to resolve the issue I'm facing?
      Here is my setup:
      Code:
      https://github.com/RobTillaart/SHT31/blob/master/examples/SHT31_rawValues/SHT31_rawValues.ino
      #include <M5AtomS3.h>
      #include <M5Unified.h>
      #include "Wire.h"
      #include "Wire.h"
      #include "SHT31.h"
      #define SHT31_ADDRESS   0x44
      uint32_t start;
      uint32_t stop;
      uint32_t cnt;
      SHT31 sht(SHT31_ADDRESS);  //  uses explicit address
      void setup()
        Serial.begin(115200);
        Wire.begin();
        Wire.setClock(100000);
        sht.begin();
        uint16_t stat = sht.readStatus();
        sht.requestData();
        cnt = 0;
      void loop()
        uint16_t rawTemperature;
        uint16_t rawHumidity;
        if (sht.dataReady())
          start = micros();
          bool success  = sht.readData();   //  default = true = fast
          stop = micros();
          sht.requestData();                //  request for next sample
          Serial.print("\t");
          Serial.print(stop - start);
          Serial.print("\t");
          if (success == false)
            Serial.println("Failed read");
          else
            rawTemperature = sht.getRawTemperature();
            rawHumidity = sht.getRawHumidity();
            Serial.print(rawTemperature, HEX);
            Serial.print(" = ");
            //  This formula comes from page 14 of the SHT31 datasheet
            Serial.print(rawTemperature * (175.0 / 65535) - 45, 1);
            Serial.print("°C\t");
            Serial.print(sht.getRawHumidity(), HEX);
            Serial.print(rawHumidity * (100.0 / 65535), 1);
            Serial.print("%\t");
            Serial.println(cnt);
            cnt = 0;
        cnt++;  //  simulate other activity
        delay(1000);
        Hello @Surya
        maybe checkout this example here. It uses an SHT30 as well.
        • teastainT
          teastain
          @surya The alternate I2C address is 45, some suppliers set it to this by default.
          Alternately you could try an sketch called an I2C scanner to see what devices are hooked up.
          This little sketch works on my AtomS3:
          #include "M5UnitENV.h"
          SHT3X sht3x;
          void setup() {           //runs once on start up
            Serial.begin(115200);  //open the serial port for USB cable
            delay(500);
            Serial.println("in setup");
            delay(1000);  //wait for a second
            if (sht3x.begin(&Wire, 0x44, 2, 1, 400000U)) {
               Serial.println("Address 44 detected");
            } else if (sht3x.begin(&Wire, 0x45, 2, 1, 400000U)) {
              Serial.println("Address 45 detected");
            } else {
              Serial.println("No ENV detected");
          -Terry
            Surya
            Thank you, @felmue and @teastain, I will give it a try.
              Surya
              The SHT30 perfectly worked with "M5UnitENV.h". Thanks again!
              Here I am encountering another challenge: I'm attempting to read temperature data from both the SHT30 and SHT40 simultaneously. However, both sensors share the same I2C address (0x44), leading to an error. I also experimented with changing the address to 0x45, but unfortunately, it didn't resolve the issue. Any advice is greatly appreciated.
              Here is my new setup:
              Code:
              #include "Wire.h"
              #include <SensirionI2CSht4x.h>
              SHT3X sht3x;
              SensirionI2CSht4x sht4x;
              float temperature, humidity;
              void setup()
                if (!sht3x.begin(&Wire, SHT3X_I2C_ADDR, 2, 1, 400000U))
                  Serial.println("Couldn't find SHT3X");
                  // while (1)
                  //   Serial.println("Couldn't find SHT3X");
                  //   delay(1000);
                sht4x.begin(Wire, SHT40_I2C_ADDR_45);
              void loop()
                temperature = humidity = NULL;
                uint16_t error;
                char errorMessage[256];
                if (sht3x.update())
                  Serial.println("-----SHT3X-----");
                  Serial.print("Temperature: ");
                  Serial.print(sht3x.cTemp);
                  Serial.println(" degrees C");
                  Serial.print("Humidity: ");
                  Serial.print(sht3x.humidity);
                  Serial.println("% rH");
                  Serial.println("-------------\r\n");
                error = sht4x.measureHighPrecision(temperature, humidity);
                if (error)
                  Serial.print("Error trying to execute measureHighPrecision(): ");
                  errorToString(error, errorMessage, 256);
                  Serial.println(errorMessage);
                else
                  Serial.println("-----SHT4X-----");
                  Serial.print("Temperature:");
                  Serial.print(temperature);
                  Serial.print("\t");
                  Serial.print("Humidity:");
                  Serial.println(humidity);
                delay(1000);
              Surya
                ajb2k3 @Surya
                @surya if you can’t physically change the addresses then you will need an I2C hub which overrides the I2C internal address
                  Surya
                  I'm just curious, Is there a way to accomplish this programmatically, without needing to physically change the addresses?
                  Surya
                  ajb2k3A teastainT 2 Replies Last reply Reply Quote 0
                    ajb2k3 @Surya
                    @surya Generally not as often the soldering of the devices pins is what's used to set the address.
                    • teastainT
                      teastain @Surya
                      @surya You need a PaHub:
                      https://docs.m5stack.com/en/unit/pahub2
                      https://shop.m5stack.com/products/i2c-hub-1-to-6-expansion-unit-pca9548apw
                      They are easy to set up and work very well.
                        Hello @Surya
                        neither SHT30 nor SHT40 allow for an I2C address change programmatically. The I2C address of SHT30 can be changed via ADDR pin; SHT40 is sold in two variants with two I2C addresses. Please also see my post here.
                          Surya
                          Okay, We're gonna buy PaHub to make it work.
                          Thank you all for your invaluable solutions and clarifications on my issue. Your help is greatly appreciated!
