Core2 as a scale - measured value jumps - measurement accurate to the gram?
I have now bought this M5Stack Core2. It's a nifty little thing with great application possibilities. So now my first project with it...I want to determine the weight of food in a food bowl. I have a "scale kit" with 4 weight sensors (HX711) for the M5Stack Core2. I actually wanted to program via UIFlow 2, which looks very appealing and simple. But as a newbie, it's a bit overwhelming. So I switched to Python after all...
So, everything is plugged in (absolutely simple) and I already have measured values on the display. But they still fluctuate too much. Countless measured values come in every second. So the idea is to collect the measured values for half a second and then only show the average value on the display. Unfortunately, I've been out of Python programming for so long that I can't do it without your help.
Code:
import os, sys, io
import M5
from M5 import *
from hardware import *
from unit import WEIGHTUnitlabel0 = None
title0 = None
label1 = None
label2 = None
weight_0 = Noneimport math
gewicht = None
gewicht1 = Nonedef btnA_wasClicked_event(state):
global label0, title0, label1, label2, weight_0, gewicht, gewicht1
weight_0.set_tare()def setup():
global label0, title0, label1, label2, weight_0, gewicht, gewicht1weight_0 = WEIGHTUnit((33,32))
M5.begin()
Widgets.fillScreen(0x222222)
label0 = Widgets.Label("label0", 45, 87, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu72)
title0 = Widgets.Title("Futter/Feed", 3, 0xffffff, 0x0000FF, Widgets.FONTS.DejaVu40)
label1 = Widgets.Label("Kg", 47, 163, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu24)
label2 = Widgets.Label(">0<", 49, 224, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu12)BtnA.setCallback(type=BtnA.CB_TYPE.WAS_CLICKED, cb=btnA_wasClicked_event)
def loop():
M5.update()
gewicht = (weight_0.get_scale_weight) / 52000
gewicht1 = round(gewicht, 1)
if gewicht1 <= 0.00:
gewicht1 = 0.00
label0.setText(str(gewicht1))
sleep(1)if name == 'main':
try:
setup()
while True:
loop()
try:
print_error_msg(e)
except ImportError:
Please help :-)
Thank you -
@dreamer This is 'roughly' how I average temperatures from sensor
float room_temp_read[5] = { 25, 25, 25, 25, 25 }; //array of five reads int x = 1; //(declared in Setup) //Read and Average subroutine if (x > 4) { x = 0; } room_temp_read[x] = tempC; room_tempAVG = (room_temp_read[0] + room_temp_read[1] + room_temp_read[2] + room_temp_read[3] + room_temp_read[4] + room_tempAVG * 8) / 13; //five reads + weighted average equals 13 x++; //increment to next array pointerThere are five reads 0-4 and a heavy weighted average (times 8) of the last average results
This is Arduino C, but just change the grammar for Python.
-Terry
